Implementing SAF on CUCM Clusters
Ahmed habib
Level 3
Level 3
I want to implement SAF on cucm clusters but I don't under the scenario and how will configuration be done and how did I check after configuration
Shall I configure every cucm cluster PUB as SAF Forwarder?
I revised SRND and SAF configuration document but it isn't clear to me https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/saf/configuration/xe-3s/saf-xe-3s-book/saf-configuring.html
Please, I want a clear document or video for this feature scenario and configuration
Note: I made the configuration in the guide but when I check I found
#show eigrp service-family ipv4 subscriptions
EIGRP-SFv4 VR(saf) Subscriptions for AS(1)/ID(192.168.178.125)
No active subscriptionsW
#show eigrp service-family ipv4 clients
EIGRP-SFv4 VR(saf) Clients for AS(1)/ID(192.168.178.125)
No Clients attached to this Forwarder
Jonathan Schulenberg
SAF has been superceeded by Inter-Cluster Lookup Service (ILS). Do not use SAF in production unless you have a corner-case that somehow precludes the use of ILS.
1) Below Will be useful for ILS
https://www.youtube.com/watch?v=CnSuho44_dw
https://info.stack8.com/blog/new-practices-for-cucm-dial-plans
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Thanks both for your interest but I don't want URI dialing
I just want to use SAF and CCD and I applied the configuration but when I try show commands
GW#show eigrp service-family ipv4 subscriptions
GW#show eigrp service-family external-client Habib
Detail data for client -- Habib
Username: admin Version: 1.2
Client Context: AS (1): AFI: IPv4 Topology: Base
Router Name: saf
Config Using as Client Basename
I made the configuration on two cucm test clusters but no one is active
Can anyone help me ?
router eigrp saf
service-family ipv4 autonomous-system 1
topology base
external-client Habib1
exit-sf-topology
exit-service-family
service-family external-client listen ipv4 5050
external-client Habib basename
username admin
password ..............
keepalive 200000
username admin
keepalive 200000
@HARIS_HUSSAIN  @Jonathan Schulenberg
I got finally the two clients registered
Is there a method to show the patterns learned on cucm or must show on RTMT ?
and Is should add manually every pattern I need to advertise ?
and Calls are done from one side only , if dialed from the other it gets fast busy tone although the learned pattern shown and all is reachable
