Import a Phonebook on Cisco 8841
timig
I can't find how to import a local contact book on cisco 8841.
I can't find any documentation on the job or self-care, i need to import 800 contacts.
I don't want to create 1 by 1 on the phone.
Bonjour,
je souhaite importer un fichier de 800 contact sur un cisco 8841. Je ne trouve pas de procédure dans la documentation du poste ou du selfcare.
Le seul choix proposé est de créer les contacts 1 par un.
Je suis preneur de toute solution ou documentation.
Cordialement,
Timig
7 Replies 7
AFAIk you need to add that one by one in self care portal. Not sure if there is  any changes with the newer  versions.
Response Signature
Steven L
 i am not sure if the personal address book synchronization still works but i would search on that.
+1 to what Steve posted. I've never used it myself, but the tool is still present in 11.5. Documentation referenced below.
Corporate and Personal Directory Setup (cisco.com)
Also, you may have already considered this, but saving that many contacts to a Personal Directory doesn't seem very user friendly or scalable.
upon further review.......
The Cisco IP Phone Address Book Synchronizer is only supported on unsupported
versions of Windows (for example, Windows XP and earlier). The tool is not
supported on newer versions of Windows. In future, it will be removed from the
Cisco Unified Communications Manager plug-ins list
This is from the doc mradell linked.   I would not go this route.
@Jaime Valencia's solution below seems to be your best option
I tried to make this option  working for a customer recently and it dint  work with newer windows  versions. And I end up adding the contacts ONE by one..
Response Signature
Jaime Valencia
It would probably be easier if you create your own directory script and then, if possible, pull that data from a data source so you can control it centrally and maybe handle it via a CSV/TXT file.
java
if this helps, please rate
Geovani
Hi there,
You won't be able to import local directories into the phone.
Your options would be to use LDAP, XML or XSI (depending on what call control you're using)
Edit (The above applies to MPP only)
thanks
Geovani
