08-14-2014 01:47 AM - edited 03-16-2019 11:44 PM
Good morning everybody,
I'm trying to configure Extension Mobility on a CUCM version 9, but I am experiencing a very strange problem. I have tried to find a solution over the Internet, but with no success. So maybe some expert can help me.
There are two strange things happening:
1) When I go to the End User configuration, I check the "Enable Mobility" flag, but there is no "Primary User Device" box. I mean, the box is absent, so there is no device to choose from. Anyway, I decided to move on. I correctly created a new Remote Destination Profile, but
2) when I add a new remote destination, I get this message: typedberrors REMOTEDESTINATION_MOBILITY_NOT_ENABLED
Can anybody help me with this?
Thank you very much!
Massimo
08-14-2014 02:29 AM
Extension Mobility, and the Mobility feature you are trying to configure are completely separate features.
Which one are you actually trying to configure?
Aaron
08-14-2014 03:02 AM
In addition to Aaron answer - please follow step-by-step guide from:
And it should work...
BR,
Dragan
