04-19-2016 02:00 AM - edited 03-17-2019 06:37 AM
Hi All,
Cisco Phones supports Inband dtmf ??
Setup
Phone --> CUCM --> CUBE ---> Service Provider
1)We are doing the SIP Integration with service provider (codec G711), where some calls are negotiated with rtp-nte and some calls are negotiated with inband.
2)Calls negotiated with inband dtmf is not working. Hope DSP resource requires for rtp-nte to Inband conversion.
3)When i tried to keep the default configuration in CUBE incoming dial peer (no dtmf -realy), CUCM couldn't negotiate for any method and declared as no dtmf for the call.
"SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=1(0) mEndppointsDtmfCaps...UNSOL=0, KPML=0, Inband=0(0) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=0
DET-MediaManager-(249255)::isMTPNeededForDTMF, No DTMF is possible for call since one (or both) party does not support any DTMF cap party1DTMF(3) party2DTMF(0)"
Thanks in Advance....
04-19-2016 04:33 AM
Cisco phones do support inband dtmf ( RFC 2833 (RTP-NTE) ). You can verify your config as per the following links which talk about different dtmf options available and how to configure them
https://supportforums.cisco.com/blog/154706
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/dtmf-relay.html
Manish
04-19-2016 04:42 AM
Hi Manish,
Thanks for your reply.
I mean the "G711 audio" as "inband" as mentioned in the CUBE dtmf relay configuration link [http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/dtmf-relay.html] which is difference from RTP-NTE..
04-19-2016 04:56 AM
As per the following
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/200412-DTMF-Relay-and-Interworking-on-CUBE.html#anc6
Voice In-band audio or G711 DTMF refers to the transport of audible tones over the voice audio stream, without any additional involvement of the signaling protocol or the DSP for their transmission other than to setup the call normally and pass the audio end to end using the G711Ulaw/Alaw codec. This means that the CUBE/IOS only passes the audio of the tones coming from one end to the other as if it is normal voice audio. The important measure to take for this method is to ensure that the calls are getting established using the G711Ulaw/Alaw codec specifically because using a codec that would compress the audio (any other codec than G711) distorts the DTMF tones and is likely render them unrecognizable to the receiving end. This is because the compression algorithm utilized by high compression codecs was designed to recognize and predict human voice and not DTMF tones.
In-band audio/G711 DTMF is supported with any VoIP signaling protocol and only requires the G711 codec to be enforced for the calls end-to-end. One must also must keep in mind that the any transcoding treatment from a low-bit-rate (LBR) codec to G711 most likely distorts the tones as well.
CUBE is able to interwork between Inband G711 DTMF (raw audio tones) to RFC2833. However, these requirements need to be met
Manish
04-20-2016 07:19 AM
As per below doc, it is recommended to use CUBE to convert raw inband DTMF into RFC2833.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/trunks.html
You will have to register a transcoder on the CUBE (not with CUCM) to do the DTMF conversion. The inbound and out bound dial peer should be configured accordingly. One with "no dtmf-relay" and other with "dtmf-relay rtp-nte"
04-21-2016 12:44 AM
Hi All,
Thanks for all your comments.
am looking for official document where it mentions "Cisco IP Phones not supporting Inband tones"..
Please help on this.
04-21-2018 11:45 PM
07-18-2016 08:52 AM
Hi gpsriramdc, I have the same issue. Did you solve?
09-29-2016 07:40 PM
hello,friend.this problem is solved?
i also face the problem.i hope i can get some information about the problem!!!!!
thank you!
