Inbound and outbound calls with CUCM
Hi guys,
I have the problem with inbound and outbound calls with CUCM.
Your help will be precious.
Aristide
10 Replies 10
Nadeem Ahmed
Aristide
Can you please share some details in order understand what exactly is the problem
Call-flow ? where you phone registered to CME or CUCM, what error message you get you dial out the number?
Br,
nadeem
Br, Nadeem Please rate all useful post.
Hi Nadeem,
the phone are registered in CUCM, I think they can be a config mismatch.
this is debug isdn q931
Oct 26 19:55:21.525: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0527
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Calling Party Number i = 0x2183, '664072581'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '624931980'
                Plan:ISDN, Type:Subscriber(local)
Oct 26 19:55:21.525: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8527
        Cause i = 0x80E4 - Invalid information element contents
Br,
Aristide
can you please post the show run from GW and also how your GW is controlled by CUCM (MGCP,H.323, SIP)
Br,
nadeem
Hi Nadeem
You can see the configuration of the router in attached.
br
Aristide
can you please make another test call inbound and outbound and collected below debugs
Debug isdn q931
debug mgcp packet
debug mgcp events
debug ip tcp transcation
also post the show isdn status
Hi Nadeem
you can see debug in attached
Thanks for the details and debug logs. can you please check E1 configuration on CUCM? also can you attached the snapshot of E1 configuration on CUCM
one thing need to confirm, is the switch type correct which needs to be same on the other side as well.
Br,
nadeem
thank you Nadeem,
I will give you a feedbak today.
hi Nadeem,
I have don't configured calling search space and partitions. It can be the issue?
