Inbound Calls FXO Port
christianbernal
Good day!!
I have a doubt, I have one CME with FXO port and a few SIP phones (5), I'm trying to get inbound calls to reach one specific extension,  for instance 1001 (receptionist).
When I dial to PSTN calls go outside without issues, perfect sound, no echo, everything works great.
The problem is when I try to get incoming calls to the fxo port to reach receptionist extension (1001) which is a SIP phone 7821 series.
My inbound config is as follows:
dial-peer voice 1 pots
 translation-profile incoming Incoming_PSTN
 incoming called-number 9010101 (example)
 direct-inward-dial
 port 0/2/0
Call is well received by the Router but can not find any method to route the call directly to the receptionist phone.
I really appreciate your help as no config had work for me. (I have tried answer-address also)
Thanks !!!
Suresh Hudda
Use "connection plar opx 1001" command at that fxo voice port(0/2/0).
Suresh
Suresh Hudda
Suresh
try this:
voice-port 0/2/0
caller-id enable
I presumed you have configured your  ext.# 1001  to be associated with your ephone-dn #.ephone # and button
example only:
ephone-dn 1
number 1001
etc.
ephone 1
device-security-mode
description
mac-address
button 1:1
