12-02-2018 01:33 PM - edited 03-17-2019 01:47 PM
We have a UC560 environment that is not receiving any inbound calls. All attempts result in a busy signal. Outgoing calls are working fine.
When I run 'terminal monitor > debug isdn q931' I get the following.
004883: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x038C
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
Exclusive, Channel 5
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '<redacted 1>'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '<redacted 2>'
004884: ISDN Se0/3/0:23 Q931: Received SETUP callref = 0x838C callID = 0x002F switch = primary-ni interface = User
004885: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x838C
004886: ISDN Se0/3/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x038C
Facility i = 0x9F8B0100A117020101020100800F455049544F4D454E4554574F524B53
0xA117020101020100800F455049544F4D454E4554574F524B53
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = <redacted 3>
004887: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x838C
004888: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x838C
Cause i = 0x80A9 - Temporary failure
004889: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x038C
004890: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x838C
The Voice Debug log shows the following.
>>>>CCAPI handed cid 2683 with tag 3001 to app "_ManagedAppProcess_Default"
006189: Dec 1 17:06:03.656: //-1/20E25B89801F/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8C2596BC; count=1
006190: Dec 1 17:06:03.656: //-1/20E25B89801F/RXRULE/regxrule_profile_translate_internal: number=<redacted 4>
type=national plan=isdn numbertype=calling
006191: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_get_RegXrule: Translation ruleset with tag=3265 doesn't exist
006192: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
006193: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_translate_internal: No match: number=<redacted 5> type=national plan=isdn
006194: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_translate_internal: number= type=UNKNOWN plan=UNKNOWN numbertype=redirect-called
006195: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006196: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
006197: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_translate_internal: No match: number= type=UNKNOWN plan=UNKNOWN
006198: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_translate_internal: number=<redacted 6>
type=national plan=isdn numbertype=called
006199: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 6
006200: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 6
006201: Dec 1 17:06:03.660: //-1/20E25B89801F/RXRULE/sed_subst: Successful substitution; pattern=<redacted 7>
matchPattern=<redacted 8> replacePattern=401 replaced pattern=401
To the best of my knowledge no configuration changes have been made. Any assistance would be appreciated.
Solved! Go to Solution.
12-03-2018 06:03 PM
I don't really understand it, but it turns out that Unity was hung up. Rebooting that in the CCA fixed everything. Still not sure why rebooting the entire UC560 box 3 times didn't have the same result.
12-02-2018 09:19 PM
You may need to check the translation rules that you use for your incoming calls. Contacting your Provider will also be useful for checking its logs.
G
12-03-2018 06:03 PM
