Inbound calls w/ block CID show up as coming from 911
kylebrogers
Level 4
Level 4
The gateway is an H323 gateway.  We've done some testing and this only happens when a person's CID is blocked (we used *67 to block it).  When the call comes in with caller ID info, the ANI is correct.  Here is an example debug (with caller ID blocked) and the corresponding dial peer:
dial-peer voice 911 pots
destination-pattern 911
incoming called-number .
no digit-strip
Mar 21 20:47:40.873: //-1/68360B788D7F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=    !!!!!!!!  It looks like no ANI comes in from the provider so I don't think it's a provider issue  !!!!!!
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=1
   cisco-anisi=3
   dest=3270
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 21 20:47:40.873: //-1/68360B788D7F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B99A1D4, Call Info(
   Calling Number= !!!! Again there is no ANI !!!!!!!,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
   Called Number=3270(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=911  !!!!!! Picks the DP tagged 911 !!!!!!!! , Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 21 20:47:40.873: //-1/68360B788D7F/CCAPI/ccCheckClipClir:
   In: Calling Number=911  !!!!!!!!!! Now alll of the sudden, the ANI is 911 !!!!!!!!!!!!!!!(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
   Out: Calling Number=911(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
Mar 21 20:47:40.873: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 21 20:47:40.873: :cc_get_feature_vsa malloc success
Mar 21 20:47:40.873:  cc_get_feature_vsa count is 3
Mar 21 20:47:40.873: :FEATURE_VSA attributes are: feature_name:0,feature_time:813908120,feature_id:64531
Mar 21 20:47:40.873: //64528/68360B788D7F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=911(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
   Called Number=3270(TON=Subscriber, NPI=ISDN))
Mar 21 20:47:40.873: //64528/68360B788D7F/CCAPI/cc_process_call_setup_ind:
   Event=0x2B966330
Mar 21 20:47:40.873: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 3270
Mar 21 20:47:40.873: //64528/68360B788D7F/CCAPI/ccCallSetContext:
   Context=0x2C17DA0C
paolo bevilacqua
You should match have se[pareta DP to match icoming calls, with "incoming called number .".
