Inbound/Outbound calls fail between CUBE and Telco
afserco
Hello Cisco Community,
We have a fairly new CUBE deployment and are using Verizon as our Telco. Vz provided us an EBI address and 2 SBCs. We have our side of the EBI connected on g0/0/0. It seems that our outbound calls are being presented to Vz but my experience is lacking and I can't tell why the call will not connect. Inbound calls don't even seem to hit our gateway, I have checked with debug ccsip messages and debug voice ccapi inout. Attached is our current configuration as well as the 2 aforementioned debugs.
Any feedback/guidance you can provide would be greatly appreciated.
AF
afserco
Hey everyone. We got the issue resolved today. The issue was two-fold. First, in order to get calls to connect we had to remove the command "zone-member security outside" on our interface connected to Verizon (gi0/0/0). Once that was done, calls would connect but we had no audio at all on either side of the call. Secondly, we then had to configure the command "zone-member security inside" on that same interface to match the internal interface (gi0/0/1) as we had a mismatch. Once that was done we then started receiving audio as well.
Hope this helps someone in the future! Cheers and have a great weekend!
10 Replies 10
afserco
Couldn't post the outbound call debug.... below is the output. Information redacted for privacy.
228506: Jan 28 08:53:20.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:914433331234@10.12.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.11.16.73:5060;branch=z9hG4bK5b2995626d7ce
From: "TJ Faudale" <sip:8588801234@10.11.16.73>;tag=4829478~4298d05d-c7a8-4d60-b145-d85d0ae50804-49959700
To: <sip:914433331234@10.12.0.2>
Date: Thu, 28 Jan 2021 13:53:20 GMT
Call-ID: 2cba0d80-121c1d0-59d6c-49100b0a@10.11.16.73
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <urn:x-cisco-remotecc:callinfo>; security= Unknown; gci= 2-9059709; isVoip, <sip:10.11.16.73:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-ID: 26d036e86335d45510e8dc5528eb6ba0;remote=00000000000000000000000000000000
Cisco-Guid: 0750390656-0000065536-0000000356-1225788170
Session-Expires: 1800
P-Asserted-Identity: "TJ Faudale" <sip:8588801234@10.11.16.73>
Remote-Party-ID: "TJ Faudale" <sip:8588801234@10.11.16.73>;party=calling;screen=yes;privacy=off
Contact: <sip:8588801234@10.11.16.73:5060>
Max-Forwards: 70
Content-Length: 0
228507: Jan 28 08:53:20.691: //-1/2CBA0D800000/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=8588801234
----- ccCallInfo IE subfields -----
cisco-ani=8588801234
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=914433331234
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
228508: Jan 28 08:53:20.692: //-1/2CBA0D800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F04C3118278, Call Info(
Calling Number=8588801234,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=914433331234(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=105, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=92888
228509: Jan 28 08:53:20.692: //-1/2CBA0D800000/CCAPI/ccCheckClipClir:
In: Calling Number=8588801234(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
228510: Jan 28 08:53:20.692: //-1/2CBA0D800000/CCAPI/ccCheckClipClir:
Out: Calling Number=8588801234(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
228511: Jan 28 08:53:20.692: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228512: Jan 28 08:53:20.692: :cc_get_feature_vsa malloc success
228513: Jan 28 08:53:20.692: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228514: Jan 28 08:53:20.692: cc_get_feature_vsa count is 1
228515: Jan 28 08:53:20.692: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228516: Jan 28 08:53:20.692: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658510558948,feature_id:28075
228517: Jan 28 08:53:20.692: //92888/2CBA0D800000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=8588801234(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=914433331234(TON=Unknown, NPI=Unknown))
228518: Jan 28 08:53:20.693: //92888/2CBA0D800000/CCAPI/cc_process_call_setup_ind:
Event=0x7F04C7EB0AC8
228519: Jan 28 08:53:20.694: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 914433331234
228520: Jan 28 08:53:20.695: //92888/2CBA0D800000/CCAPI/ccCallSetContext:
Context=0x7F04DB3D9478
228521: Jan 28 08:53:20.695: //92888/2CBA0D800000/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 92888 with tag 105 to app "_ManagedAppProcess_Default"
228522: Jan 28 08:53:20.697: //92888/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.12.4
Session-ID: 00000000000000000000000000000000;remote=26d036e86335d45510e8dc5528eb6ba0
Content-Length: 0
228523: Jan 28 08:53:20.697: //92888/2CBA0D800000/CCAPI/ccCallProceeding:
228524: Jan 28 08:53:20.698: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=110, Params=0x7F04DB76A810, Progress Indication=NULL(0)
228525: Jan 28 08:53:20.698: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228526: Jan 28 08:53:20.699: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228527: Jan 28 08:53:20.699: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Destination Pattern=91443333...., Called Number=14433331234, Digit Strip=FALSE
228528: Jan 28 08:53:20.699: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Called Number=14433331234(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=TJ Faudale
Account Number=8588801234, Final Destination Flag=TRUE,
Guid=2CBA0D80-0001-0000-0000-016449100B0A, Outgoing Dial-peer=110
228529: Jan 28 08:53:20.699: //92888/2CBA0D800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=14433331234
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
228530: Jan 28 08:53:20.700: //92888/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F04C3118278, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=8588801234,(Calling Name=TJ Faudale)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=14433331234(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=110, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
228531: Jan 28 08:53:20.700: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228532: Jan 28 08:53:20.700: :cc_get_feature_vsa malloc success
228533: Jan 28 08:53:20.700: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228534: Jan 28 08:53:20.700: cc_get_feature_vsa count is 2
228535: Jan 28 08:53:20.700: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228536: Jan 28 08:53:20.700: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658510545732,feature_id:28076
228537: Jan 28 08:53:20.700: //92889/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
228538: Jan 28 08:53:20.701: //92889/2CBA0D800000/CCAPI/ccCallSetContext:
Context=0x7F04DB76A790
228539: Jan 28 08:53:20.701: //92888/2CBA0D800000/CCAPI/ccSaveDialpeerTag:
228540: Jan 28 08:53:20.702: //92889/2CBA0D800000/CCAPI/cc_api_call_proceeding:
Interface=0x7F04C3118278, Progress Indication=NULL(0)
228541: Jan 28 08:53:20.703: //92889/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
228542: Jan 28 08:53:20.703: cc_api_get_xcode_stream : 5013
228543: Jan 28 08:53:20.704: //92889/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:14433331234@X.X.X.147:5206 SIP/2.0
Via: SIP/2.0/UDP X.X.X.190:5060;branch=z9hG4bK1B5813CB
Remote-Party-ID: "TJ Faudale" <sip:8588801234@X.X.X.190>;party=calling;screen=yes;privacy=off
From: "TJ Faudale" <sip:8588801234@X.X.X.190>;tag=831D5265-1AFF
To: <sip:14433331234@X.X.X.147>
Call-ID: 3F3644B-60A711EB-A0B7E0B9-5E4BB6C8@X.X.X.190
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1611842000
Contact: <sip:8588801234@X.X.X.190:5060>
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 321
v=0
o=CiscoSystemsSIP-GW-UserAgent 1169 1883 IN IP4 X.X.X.190
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
m=audio 17940 RTP/AVP 0 18 8 101
c=IN IP4 X.X.X.190
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
228544: Jan 28 08:53:21.204: //92889/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 28 Jan 2021 13:53:21 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842001
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228545: Jan 28 08:53:22.203: //92889/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 28 Jan 2021 13:53:22 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842002
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228546: Jan 28 08:53:24.203 EST: %VOICE_IEC-3-GW: SIP: Internal Error (1xx wait timeout): IEC=1.1.129.7.59.0 on callID 92889 GUID=2CBA0D80000100000000016449100B0A
228547: Jan 28 08:53:24.203: //92889/2CBA0D800000/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x7F04C3118278, Call Id=92889
228548: Jan 28 08:53:24.203: //92889/2CBA0D800000/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
228549: Jan 28 08:53:24.204: //92888/2CBA0D800000/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
228550: Jan 28 08:53:24.204: //92889/2CBA0D800000/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=92889
228551: Jan 28 08:53:24.204: //92889/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
228552: Jan 28 08:53:24.205: //92889/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
228553: Jan 28 08:53:24.205: //92889/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F04C3118278, Tag=0x0, Call Id=92889,
Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
228554: Jan 28 08:53:24.206: //92889/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
228555: Jan 28 08:53:24.206: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228556: Jan 28 08:53:24.206: :cc_free_feature_vsa freeing 7F04C7E93338
228557: Jan 28 08:53:24.206: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228558: Jan 28 08:53:24.206: vsacount in free is 1
228559: Jan 28 08:53:24.208: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=111, Params=0x7F04DB002F08, Progress Indication=NULL(0)
228560: Jan 28 08:53:24.208: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228561: Jan 28 08:53:24.208: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228562: Jan 28 08:53:24.208: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
228563: Jan 28 08:53:24.208: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Guid=2CBA0D80-0001-0000-0000-016449100B0A, Outgoing Dial-peer=111
228564: Jan 28 08:53:24.209: //92888/2CBA0D800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=14433331234
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
228565: Jan 28 08:53:24.209: //92888/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=111, Call Count On=FALSE,
228566: Jan 28 08:53:24.209: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228567: Jan 28 08:53:24.209: :cc_get_feature_vsa malloc success
228568: Jan 28 08:53:24.209: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228569: Jan 28 08:53:24.209: cc_get_feature_vsa count is 2
228570: Jan 28 08:53:24.209: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228571: Jan 28 08:53:24.210: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658510545732,feature_id:28077
228572: Jan 28 08:53:24.210: //92890/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
228573: Jan 28 08:53:24.210: //92890/2CBA0D800000/CCAPI/ccCallSetContext:
Context=0x7F04DB002E88
228574: Jan 28 08:53:24.210: //92888/2CBA0D800000/CCAPI/ccSaveDialpeerTag:
228575: Jan 28 08:53:24.212: //92890/2CBA0D800000/CCAPI/cc_api_call_proceeding:
228576: Jan 28 08:53:24.213: //92890/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
228577: Jan 28 08:53:24.213: cc_api_get_xcode_stream : 5013
228578: Jan 28 08:53:24.214: //92890/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:14433331234@X.X.X.19:6446 SIP/2.0
Via: SIP/2.0/UDP X.X.X.190:5060;branch=z9hG4bK1B59A98
From: "TJ Faudale" <sip:8588801234@X.X.X.190>;tag=831D601B-1BE4
To: <sip:14433331234@X.X.X.19>
Date: Thu, 28 Jan 2021 13:53:24 GMT
Call-ID: 60AFA71-60A711EB-A0B9E0B9-5E4BB6C8@X.X.X.190
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842004
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
o=CiscoSystemsSIP-GW-UserAgent 1916 4205 IN IP4 X.X.X.190
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
m=audio 17942 RTP/AVP 0 18 8 101
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228579: Jan 28 08:53:24.713: //92890/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228580: Jan 28 08:53:25.713: //92890/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 28 Jan 2021 13:53:25 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842005
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228581: Jan 28 08:53:27.382: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.12.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.11.16.72:5060;branch=z9hG4bK1815d7b6fc7f8
To: <sip:10.12.0.2>
Date: Thu, 28 Jan 2021 13:53:27 GMT
Call-ID: 30e62b00-121c1d7-179b8-48100b0a@10.11.16.72
CSeq: 101 OPTIONS
Contact: <sip:10.11.16.72:5060>
Max-Forwards: 0
Content-Length: 0
228582: Jan 28 08:53:27.384: //92891/07EED57EA0BA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.12.0.2>;tag=831D6C7D-13A8
CSeq: 101 OPTIONS
Accept: application/sdp
Content-Length: 360
v=0
o=CiscoSystemsSIP-GW-UserAgent 894 4548 IN IP4 10.12.0.2
s=SIP Call
c=IN IP4 10.12.0.2
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 10.12.0.2
m=image 0 udptl t38
c=IN IP4 10.12.0.2
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
228583: Jan 28 08:53:27.713 EST: %VOICE_IEC-3-GW: SIP: Internal Error (1xx wait timeout): IEC=1.1.129.7.59.0 on callID 92890 GUID=2CBA0D80000100000000016449100B0A
228584: Jan 28 08:53:27.713: //92890/2CBA0D800000/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x7F04C3118278, Call Id=92890
228585: Jan 28 08:53:27.713: //92890/2CBA0D800000/CCAPI/cc_api_call_disconnected:
228586: Jan 28 08:53:27.714: //92888/2CBA0D800000/CCAPI/ccCallReleaseResources:
228587: Jan 28 08:53:27.714: //92890/2CBA0D800000/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=92890
228588: Jan 28 08:53:27.715: //92890/2CBA0D800000/CCAPI/ccCallDisconnect:
228589: Jan 28 08:53:27.715: //92890/2CBA0D800000/CCAPI/ccCallDisconnect:
228590: Jan 28 08:53:27.715: //92890/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F04C3118278, Tag=0x0, Call Id=92890,
228591: Jan 28 08:53:27.716: //92890/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
228592: Jan 28 08:53:27.716: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228593: Jan 28 08:53:27.716: :cc_free_feature_vsa freeing 7F04C7E93338
228594: Jan 28 08:53:27.716: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228595: Jan 28 08:53:27.716: vsacount in free is 1
228596: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=101, Params=0x7F04DA946090, Progress Indication=NULL(0)
228597: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228598: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/ccCheckClipClir:
228599: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Destination Pattern=91..........$, Called Number=14433331234, Digit Strip=FALSE
228600: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/ccCallSetupRequest:
Guid=2CBA0D80-0001-0000-0000-016449100B0A, Outgoing Dial-peer=101
228601: Jan 28 08:53:27.718: //92888/2CBA0D800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=14433331234
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
228602: Jan 28 08:53:27.719: //92888/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=101, Call Count On=FALSE,
228603: Jan 28 08:53:27.719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228604: Jan 28 08:53:27.719: :cc_get_feature_vsa malloc success
228605: Jan 28 08:53:27.719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228606: Jan 28 08:53:27.719: cc_get_feature_vsa count is 2
228607: Jan 28 08:53:27.719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
228608: Jan 28 08:53:27.719: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658510545732,feature_id:28078
228609: Jan 28 08:53:27.720: //92892/2CBA0D800000/CCAPI/ccIFCallSetupRequestPrivate:
228610: Jan 28 08:53:27.720: //92892/2CBA0D800000/CCAPI/ccCallSetContext:
Context=0x7F04DA946010
228611: Jan 28 08:53:27.720: //92888/2CBA0D800000/CCAPI/ccSaveDialpeerTag:
228612: Jan 28 08:53:27.722: //92892/2CBA0D800000/CCAPI/cc_api_call_proceeding:
228613: Jan 28 08:53:27.723: //92892/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
228614: Jan 28 08:53:27.723: cc_api_get_xcode_stream : 5013
228615: Jan 28 08:53:27.724: //92892/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP X.X.X.190:5060;branch=z9hG4bK1B5ACA8
From: "TJ Faudale" <sip:8588801234@X.X.X.190>;tag=831D6DD1-1924
Call-ID: 82267D5-60A711EB-A0BCE0B9-5E4BB6C8@X.X.X.190
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842007
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
o=CiscoSystemsSIP-GW-UserAgent 6464 9713 IN IP4 X.X.X.190
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
m=audio 17944 RTP/AVP 0 18 8 101
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228616: Jan 28 08:53:28.223: //92892/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 28 Jan 2021 13:53:28 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842008
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228617: Jan 28 08:53:29.223: //92892/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 28 Jan 2021 13:53:29 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1611842009
Expires: 180
Max-Forwards: 69
Content-Length: 321
v=0
s=SIP Call
c=IN IP4 X.X.X.190
t=0 0
c=IN IP4 X.X.X.190
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
228618: Jan 28 08:53:29.728: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.11.16.73:5060;branch=z9hG4bK5b29a7a72a34c
To: <sip:10.12.0.2>
Call-ID: 32175800-121c1d9-59d6d-49100b0a@10.11.16.73
CSeq: 101 OPTIONS
Contact: <sip:10.11.16.73:5060>
Max-Forwards: 0
Content-Length: 0
228619: Jan 28 08:53:29.730: //92893/0954A667A0BD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.12.0.2>;tag=831D75A7-1D1E
CSeq: 101 OPTIONS
Content-Length: 361
v=0
o=CiscoSystemsSIP-GW-UserAgent 4653 9121 IN IP4 10.12.0.2
s=SIP Call
c=IN IP4 10.12.0.2
t=0 0
c=IN IP4 10.12.0.2
m=image 0 udptl t38
c=IN IP4 10.12.0.2
a=T38FaxVersion:0
228620: Jan 28 08:53:29.892: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:914433331234@10.12.0.2:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
228621: Jan 28 08:53:29.893: //92888/2CBA0D800000/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7F04C3118278, Call Id=92888
228622: Jan 28 08:53:29.893: //92888/2CBA0D800000/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
228623: Jan 28 08:53:29.893: //92892/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
228624: Jan 28 08:53:29.893: //92892/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
228625: Jan 28 08:53:29.894: //92888/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
228626: Jan 28 08:53:29.894: //92888/2CBA0D800000/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
228627: Jan 28 08:53:29.895: //92888/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
228628: Jan 28 08:53:29.896: //92888/2CBA0D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:914433331234@10.12.0.2>;tag=831D764D-1D55
CSeq: 101 INVITE
Reason: Q.850;cause=16
Content-Length: 0
228629: Jan 28 08:53:29.963: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:914433331234@10.12.0.2:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
228630: Jan 28 08:53:29.965: //92888/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F04C3118278, Tag=0x0, Call Id=92888,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
228631: Jan 28 08:53:29.965: //92888/2CBA0D800000/CCAPI/cc_api_call_disconnect_done:
228632: Jan 28 08:53:29.965: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228633: Jan 28 08:53:29.965: :cc_free_feature_vsa freeing 7F04C7E966D8
228634: Jan 28 08:53:29.965: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
228635: Jan 28 08:53:29.965: vsacount in free is 1
Are you sure that the service provider is using port 5206 for their SBC?
Response Signature
Hi Roger. Vz specifically sent us an email detailing the SBCs and the ports we should use. I thought it was odd as well as we usually use 5060.
We can see Disconnect Cause=102,  And in the first post you mentioned that incoming calls are not even landing on the CUBE, looks like something wrong with the trunk between you and  telco.Hope you already opened a case and working with them.
Response Signature
Rajan
Hi AF,
I would say first check whether the SIP trunk is established. YOu have configured UDP for the SIP trunk. SO confirm whether that is what the provided wanted.
Another suggestion, I could see isyou have configured Session groups but still used individual dial-peers pointing to each of their SBCs. So instead of using " session target ipv4:X.X.X.147:5206" in the outbound dial-peers, use the command " session server-group 2" which will have all their SBCs mentioned in the group.
dial-peer voice 101 voip
 description Outbound CUBE to Verizon SCB1
 translation-profile outgoing strip9
 destination-pattern 91..........$
 session protocol sipv2
 I do not see any debugs attached.
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
Hi Rajan,
Thank you for the reply. We have confirmed that our network communication with Verizon is up. Verizon turned-up the Trunk 2 weeks ago. We have an IPSEC Tunnel between us and Vz and we can ping the Vz EBI as well as the gateways of the SBCs.
I had a TAC case open and TAC advised that we have dial-peers using individual SBCs. But thank you for the recommendation.
Sorry about the debug, I had  issues posting it originally. I have since posted the debug for the outbound call.
From the debugs, it looks like you are sending the Invite for the call to the provider multiple times but not getting any response from them and the call fails with the cause code 102 as its getting timed out:
Either your invite is not reaching them or if they get it, you need to check with them on the reason for no response.
Rajan
afserco
Thanks everyone for the feedback. We have a call with Verizon tomorrow morning. I'll let you know what the issue ends up being.
afserco
I’m not sure that the SBC functionality would work with the zone based firewall functionality that you seem to be using. With the setup you have now would you actually have any security functionality enabled between the two interfaces?  I’m not by any means an expert on the security side of functions in the routers, so not to sure about this. Just my layman’s take on what you have described.
Response Signature
