Inbound SRST call backs
hutto.txed.net
Let me see if I can explain what I am trying to do, with my SRST.  I have configured Device pools and Route Patterns that use the SRST router to call 911 from ip phones in the class rooms.  This is working Great, I have a hard line to the phone port on the SRST router setup so when a phone in the school dials 911 they all go through the hard line correctly sending 911 services to the correct location, no problem here.  The problem is when we have a 911 hang up, and 911 operator calls back they dial the hard line number that is attached to the router and they get no answer or busy and they send some one out all the time.  My question, is there a way to forward call backs from this line to a internal extension manned by a receptionist or a live body.  I am running Call Manager 7.1.  I hope this makes sense and any help will be great.
9 Replies 9
Chris Deren
What is the "hard line" is this an FXO trunk line? What protocol are you using to control the GW, i.e. MGCP/H323/SIP?
Chris
It is an FXS port, and I am using h323/
FXS line connected to telco for e911?  Is it FXS/DID with DID number riding on it?  Are is there specific number for each circuit and possibly a FXO circuit?
Chris
Never mind I just looked at the back of the router,  It is a fxo port and I have a dedicated DID line coming into it, from the telco.
Then what you do is configure the port with plar config "connection plar opx XXXX" where XXXX is the destination you want the call go to.
HTH, please rate all useful posts!
Chris
It is not working, here is my router config.  it is a 2800 router.  The 5493 is the extension I want it to ring at.
Current configuration : 2672 bytes
version 12.4
hostname RES.SRST
boot-start-marker
boot-end-marker
enable secret 5 $1$LCbf$DbPaVzKa6WqIwjCr9Wgmz1
aaa new-model
aaa authentication login default group radius local
aaa authentication enable default group radius enable
aaa authorization exec default group radius local
aaa accounting suppress null-username
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
ip cef
ip domain name hutto.txed.net
trunk group  POTS
max-calls any 2
hunt-scheme sequential
voice-card 0
username calence privilege 15 secret 5 $1$Vd3/$dJklNe9OFI3FgAKesnbXX0
username admin privilege 15 secret 5 $1$R/fk$tkqaLI6SHbc5bpeRxt0rg.
interface FastEthernet0/0
ip address 10.140.100.2 255.255.254.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.140.100.2
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.140.100.1
ip http server
no ip http secure-server
radius-server host 10.64.86.5 auth-port 1645 acct-port 1646 key 7 12311003065B4D170E
radius-server host 10.64.84.99 auth-port 1645 acct-port 1646 key 7 12311003065B4D170E
control-plane
voice-port 0/1/0
trunk-group POTS 7
timing hookflash-out 500
connection plar opx 5493
description POTS line
voice-port 0/1/1
trunk-group POTS 5
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 911 pots
trunkgroup POTS
description *** Outbound 911 ***
destination-pattern 911
forward-digits 3
dial-peer voice 9911 pots
trunkgroup POTS
destination-pattern 9911
forward-digits 3
dial-peer voice 100 pots
trunkgroup POTS
description *** Outbound local ***
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 50 voip
destination-pattern [1-8]...
session target ipv4:10.55.100.5
incoming called-number .T
dial-peer voice 51 voip
preference 2
session target ipv4:10.200.100.5
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.140.100.2 port 2000
max-ephones 25
max-dn 50
system message primary SRST - Fallback
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
scheduler allocate 20000 1000
ntp clock-period 17178111
ntp server 10.64.84.1
end
So, what is extension 5493 defined as on CUCM?
Does the CSS applied to the H323 on CUCM have access to the parition assigned ot 5943?
Chris
Not sure what you ment by definded on CUCM.  Partitions? CSS?, How can I tell what CSS is applied to the H323 on CUCM.  I did not configure this router, it was done a while back.
Your GW configuration points to DN 5493, what is that DN in CUCM defined as?
When the call arrives to this GW, via voip dial-peer it redirects the call to CUCM, CUCM has the GW defined as H323 GW with name being the IP address of the GW, it has Calling Search Space applied to it. You need to ensure that the applied CSS lists partition that is assigned to the 5493 extension.
HTH,
Chris
