Incoming calls not ringing in- CME site, equipment returning a fast busy signal to the carrier.
ram.r.atkuri1
We have a CME site with 2811 router and FXO cards. I am able to hear the ring but the phone does not ring. Internal calls work fine, outbound calls are fine. But phones not receiving inbound calls. Help please.
15 Replies 15
dsobrinho
Level 9
Level 9
Hi ram.r.atkuri1,
Could you please share with us the  output of configuration.
- show dial-peer voice summary
- show voice port
Best regards,
Daniel Sobrinho
Daniel Sobrinho
#show dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
2      voip  up   down                              0  syst
100    voip  up   down                              0  syst
101    voip  up   up             16..               0  syst ipv4:172.17.4.10
102    voip  up   up             13..               0  syst ipv4:172.17.4.10
103    voip  up   up             36..               0  syst ipv4:10.21.223.2
104    voip  up   up             10..               0  syst ipv4:172.17.4.10
105    voip  up   up             11..               0  syst ipv4:172.17.4.10
106    voip  up   up             30..               0  syst ipv4:10.21.219.30
107    voip  up   up             31..               0  syst ipv4:10.21.219.30
108    voip  up   up             33..               0  syst ipv4:10.21.217.30
109    voip  up   up             12..               0  syst ipv4:172.17.4.10
110    voip  up   up             17..               0  syst ipv4:172.17.4.10
111    voip  up   up             15..               0  syst ipv4:172.17.4.10
112    voip  up   up             0475               0  syst ipv4:172.17.4.10
113    voip  up   up             14..               0  syst ipv4:172.17.4.10
114    voip  up   up             34..               0  syst ipv4:10.21.218.2
115    voip  up   up             274                0  syst ipv4:172.17.4.10
116    voip  up   up             50..               0  syst ipv4:172.17.4.10
117    voip  up   up             37..               0  syst ipv4:10.21.214.30
118    voip  up   up             38..               0  syst ipv4:172.17.4.10
1      pots  up   up             91[2-9].........   0                      up   trunkgroup DEPWheeling-POTS
120    pots  up   up             3554               0                      up   0/0/0
121    pots  up   up             3552               0                      up   0/0/1
122    pots  up   up             3553               0                      up   0/0/2
123    pots  up   up             3551               0                      up   0/0/3
124    pots  up   up             3554               0                      up   0/1/0
125    pots  up   up             3553               0                      up   0/1/1
126    pots  up   up             5510               0                      up   0/1/3
20001  pots  up   up             3501$              0                           50/0/2
20002  pots  up   up             3502$              0                           50/0/3
20003  pots  up   up             3503$              0                           50/0/4
20004  pots  up   up             3526$              0                           50/0/5
20005  pots  up   up             3505$              0                           50/0/6
20006  pots  up   up             3506$              0                           50/0/7
20007  pots  up   up             3507$              0                           50/0/8
20008  pots  up   up             3508$              0                           50/0/9
20009  pots  up   up             3509$              0                           50/0/10
20010  pots  up   up             3510$              0                           50/0/11
20011  pots  up   up             3511$              0                           50/0/12
20012  pots  up   up             3512$              0                           50/0/13
20013  pots  up   up             3513$              0                           50/0/14
20014  pots  up   up             3514$              0                           50/0/15
20015  pots  up   up             3515$              0                           50/0/16
20016  pots  up   up             3516$              0                           50/0/17
20017  pots  up   up             3517$              0                           50/0/18
20018  pots  up   up             3518$              0                           50/0/19
20019  pots  up   up             3519$              0                           50/0/20
20020  pots  up   up             3520$              0                           50/0/21
20021  pots  up   up             3521$              0                           50/0/22
20022  pots  up   up             3522$              0                           50/0/23
20023  pots  up   up             3523$              0                           50/0/24
20024  pots  up   up             3500$              0                           50/0/26
I see tha that you have a plar configured in each FXO to a specific extension number as show below:
126    pots  up   up             5510               0                      up   0/1/3  okay to answer
Now in this list below you can see the extension registered:
Only extesion 5510 is ready to answer. The plar is point to a specifc extension numbers if the extension number is unreachable (3551;3552;3553;3554) the external call can not be answered.
You can change the plar number in each FXO to an extension registered or create a Hunt-Group with a pool of extension registered.
config term
voice-port 0/0/0
 connection plar 3502
voice-port 0/0/1
 connection plar 3510
Best regards
Daniel Sobrinho
Daniel Sobrinho
@dsobrinho
Can I make all the connection plars as 5510 in the voice ports?
Hi ram.r.atkuri,
Yes, Only verify before who is extension 5510. I recommend setup to Telephonist.
Best regards,
Daniel
Daniel Sobrinho
Hi Daniel,
I tried to call the number which has the plar 5510 associated. It rings twice and gives me a fast busy signal. Do you recommend making all the connection plars set to 5510?
Ram Atkuri.
Hi ram.r.atkuri1,
Can you please reproduce the issue and collect these debugs:
Debugs on the CME:
To Collect the debugs use this procedure:
https://supportforums.cisco.com/docs/DOC-16310
Conf t
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
voice iec syslog
Exit
<enable debug>
debug ccsip all
debug voip ccapi inout
debug voip vtsp default
debug voip vtsp session
-Enable Putty to log all output to a file here and run the failed call
scenario test, then run the following and collect the output:
show debug
Undebug all
Terminal length 0
Show log
Terminal default length
And let me know the exact:
Calling party:
Called party:
Attach the file here.
Daniel Sobrinho
Hi Daniel,
I could not get a right answer yet. There is still incoming calls problem. I have attached the debug. Could you please help me out. It shows disconnect cause value 1 (number unassigned) and cause value 17 (user busy).
I can see in the debug the destination called as extension 3551. I believe that you have a connection plar applied yet in one of FXO to 3551. Verify the FXO again. If you do not have the extension connected (IP PHONE connected and registered) the answer  allways will be cause value 1 (number unassigned).
Jun 29 2015 07:42:07.730 EDT: //-1/B49948589233/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=3049578157
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3551
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Daniel Sobrinho
I changed '3551' to '3500' which is an extension in use. When I dialed the 10 digit number it is ringing on her extension. She also has 3 other lines on the same phone. How can I make it to ring?
I do not know if I understand your question now. You can assign the 3 extensions to ring?
Note: One solution that I propose, would be create  a hunt-group with one Pilot Number that will be assigned in FXOs ports, inside the hunt-group you can insert two o more extension numbers. In the hunt-group you can select the algorithm (to ring in all extension in the same time, or to ring in longest Idle extension). There are many others configuration that you can use.
Use this documment as reference (find for hunt group)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmecover.html#pgfId-1118926
Best regards,
Daniel Sobrinho
Daniel Sobrinho
@dsobrinho +5
Just apply this solution ...your problem will be resolved
Thank you for a very fast reply @dsobrinho. Here is the show voice port output.
thanks,
Ram
