06-10-2011 02:30 AM - edited 03-16-2019 05:23 AM
we have an Cisco 2911 voice gateway configured with 6 BRI Interfaces and connected to an CUCM 8.0.3
Incoming calls from PSTN are delayed in call proceeding by round about 14 seconds! Here is a debug of this:
Jun 10 09:00:41.317: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8 callref = 0x55
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2181, '39982XXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, 'XXXX142'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
Jun 10 09:00:41.317: ISDN BR0/1/1 Q931: TX -> SETUP_ACK pd = 8 callref = 0xD5
Channel ID i = 0x89
Exclusive, B1
Jun 10 09:00:56.321: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xD5
Jun 10 09:00:56.337: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8 callref = 0xD5
You can see the delay between TX -> SETUP_ACK and TX -> CALL_PROC. There a 15 Seconds while the caller no hear ringback tone.
What can be the reason of this?
Here is a sample of BRI Interface configuration:
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn static-tei 0
Can somebody help?
06-10-2011 02:36 AM
Which exact IOS are you using?
DP config ?
06-10-2011 03:03 AM
IOS is
(C2900-UNIVERSALK9-M), Version 15.1(4)M
Dial-Peer:
dial-peer voice 1 pots
description incoming from PSTN
incoming called-number .
direct-inward-dial
dial-peer voice 10 voip
description to CUCM
destination-pattern 12345T
modem passthrough nse codec g711alaw
session target ipv4:192.168.161.240
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax protocol pass-through g711alaw
no vad
no supplementary-service h225-notify cid-update
06-10-2011 03:16 AM
On the voip dial peer make it a pattern match, something like:-
destination-pattern 12345...
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
06-10-2011 03:24 AM
I think they used T believing it is needed to support different lenght called numbers and presence overlap-receiving.
In reality, what is needed, in these cases is avoid overlapping numbers, and use separate DPs.
05-25-2012 09:44 AM
Had this issue resolved? We have same problem in our network.
Please help me with the resolution if you have already got it.
Appreciate your help.
Sanadh
05-25-2012 09:53 AM
Can you send you sh run here and a
debug voip ccapi inout
05-25-2012 10:39 AM
Thanks for your immediate response.
Issue resolved now. It was dial-peer issue. Our subscriber CUCM 10.99.4.1 is down and not in cluster.
So going to next dial-peer (dial-peer voice 8 voip) was taking 15 seconds.
dial-peer voice 7 voip
destination-pattern 3096....
progress_ind setup enable 1
progress_ind progress enable 1
progress_ind connect enable 1
progress_ind disconnect enable 8
session target ipv4:10.99.4.1
codec g711ulaw
preference 1
session target ipv4:10.99.4.2
codec g711ulaw
Thanks & Regards,
Sanadh
05-25-2012 10:53 AM
Sanadh,
To avoid this in the future configure the following
voice class h323 1
h225 timeout tcp establish 3
voice-class h323 1
WIth this command when the primary callmanager on dial-peer 7 is down, the next callmanager on dial-peer 8 will be tried within 3 secs.
Pls rate useful posts
05-27-2012 09:41 PM
Thank you for the valuable input, i will configure the same in voice gateway.
This will help us to avoid delay in calls, if the primary dial-peer is not matched.
Thanks & Regards,
Sanadh
