09-06-2012 07:15 AM - edited 03-16-2019 01:03 PM
I have CUCM 8.6 and voice gateway that is working a " SIP Trunk " with ISP or Telco company so that there is no E1 or analog Connection, however my problem is
from outside to inside
Ex: Mobile A) is calling by 97205238 ---> to my Extenstion (DID) 850
the DID phone will not hear the voice and the calling number will still ring
in other words : there is problem " unable to hear the incoming calls and the calling will ring when i open the call "
Notes:
Note1 : there is translation pattern 222708XX to 8XX for incoming calls
Note2: DID range : 800-899
Note3: I am using two dial peers , one of them "SIP " going to ISP or Telco Gateway IP address, and the other dial peer " h323"going to call manager ip address
Note 4: outgoing calls are working fine
if you want to see the configuration , please attch the file
thanks and regards
09-10-2012 01:46 AM
Happy you resolved it. But please next time try and describe your p roblem properly. You said you were not hearing ringback..A xocder will never solve ringback issue. Obviously th eproblem you had was different to this..Anyway next time to help you better try and describe your problem properly...Good luck
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
