incoming calls problem (unable to hear the calls)
Yazen Alaa
I have CUCM 8.6 and voice gateway that is working  a " SIP Trunk " with ISP or Telco company so that there is no E1 or analog Connection, however my problem is
from outside to inside
Ex:  Mobile  A) is calling by 97205238 ---> to  my Extenstion (DID) 850
the DID phone will not hear the voice and the calling number will still ring
in other words : there is problem " unable to hear the incoming calls and the calling will ring when i open the call "
Notes:
Note1 : there is translation pattern      222708XX to 8XX for incoming calls
Note2: DID range : 800-899
Note3: I am using two dial peers , one of them "SIP " going to ISP or Telco Gateway IP address, and the other dial peer " h323"going to call manager ip address
Note 4: outgoing calls are working fine
if you want to see the configuration , please attch the file
thanks and regards
15 Replies 15
paolo bevilacqua
That usually happens when you're using a thid-party router that doesn support SIP-ALG, so it never opens the UDP port and the result is one way audio.
Use a good router like a Cisco, and the problem will go away.,
Hi Paolo
regarding voice gatewat it is cisco2900 series and it is not third party , what you think the problem is ? and solution ?
thanks
Yazen Alaa
Hi all
any updates ?
may i am missing to configure " Ip routing " commands ????
thanks and regards
Yazen Alaa
Any reply ???
thanks
HI, I dont understand what you mean by the calling will ring. Do you mean that you do not hear your phone ringing when it is called from outside? But when you asnwer it, the call connects?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Exactly
thanks
Is not that if you solicit answers every 5 minuts you will get more.
Post config for all devices involved.
Yazen Alaa
this is the configuration , that i have in the router
hostname ARCH_ROUTER
boot-start-marker
boot-end-marker
card type e1 0 3
enable secret 4 gMj8cDXfU6CzFI9r1WoD5G6GTI5KwVY2O2lU2DSTP4c
no aaa new-model
clock timezone KW 3 0
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 10.10.1.1 10.10.1.20
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.11 192.168.1.12
ip dhcp pool VOICE
network 10.10.1.0 255.255.255.0
default-router 10.10.1.5
option 150 ip 10.10.1.10
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
license udi pid CISCO2901/K9 sn FCZ1624711H
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
pri-group timeslots 1-31
interface Embedded-Service-Engine0/0
no ip address
shutdown
description ## Connected to Fasttlco P2P ##
ip address 10.101.6.18 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description ## Internal Network ##
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.10.15 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
interface GigabitEthernet0/1.90
encapsulation dot1Q 90
ip address 10.10.1.5 255.255.255.0
ip helper-address 10.10.1.5
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.1.5
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.10
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/3/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
dial-peer voice 10 voip
destination-pattern .T
session protocol sipv2
session target ipv4:10.200.200.50
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 20 voip
destination-pattern 222708..
session target ipv4:10.10.1.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
I don't see any public IP so I doubt that is your internet router.
First and foremost, I will suggest that you reconfigure your dial-peers. You have two dial-peers for incoming called number. One is using sip, the other is using h323.
I suggest you configure a more specific match for the incoming called number from your sip provider. Eg incoming called number 222708...
incoming called-number 222708..
secondly, I will suggest you change your h323 trunk from cucm to sip trunk, so that you have and end to end sip solution. I have seen many ringback issues resolve this way.
So are you willing to try and convert your h323 to sip? Can you do the above metioned dial-peer config and then test again..
Send the ff: debug
debug ccsip messages
debug voip ccapi inout
rsculthorp
You can also verify that there are no ACLs preventing the internal VOIP device from reaching the gateway and vice versa.  I have run in to the issue before where even though the Callamanger can reach the gateway, the end user device was being blocked by an ACL and thus the initial call setup functions normally (because the callmanager can reach the gateway and the end user device) but once the connection is made and the call is handed off, then the audio portion of the call is dropped.
Also, I just noticed that you are running RIP, could it be possible that you are having a route path issue between the gateway and the phone?  The gateway may be trying to reach the phone through a different path that the phone is using to reach the gateway.
Rod
I did add " incoming called-number 222708.. " , still the same problem and
i did add " voice rtp send-recv " and the same problem
Note : there is no NAtting , and there is no ACL list to prevent that
then i did debug as mention as below :
   Accounting=1, Call Id=871
Sep  9 12:01:41.907: //871/39F53AA89C8B/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=47)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Sep  9 12:01:41.907: //871/39F53AA89C8B/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Sep  9 12:01:41.911: //871/39F53AA89C8B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30C55BA4, Tag=0x0, Call Id=871,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep  9 12:01:41.911: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  9 12:01:41.911: :cc_free_feature_vsa freeing 2BE6E968
Sep  9 12:01:41.911:  vsacount in free is 1
Sep  9 12:01:41.911: //870/39F53AA89C8B/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10, Params=0x2A659F30, Progress Indication=NULL(0)
Sep  9 12:01:41.911: //870/39F53AA89C8B/CCAPI/ccCheckClipClir:
   In: Calling Number=97688053(TON=Unknown, NPI=Unknown, Screening=User, Passed,
Presentation=Allowed)
   Out: Calling Number=97688053(TON=Unknown, NPI=Unknown, Screening=User, Passed
, Presentation=Allowed)
   Destination Pattern=.T, Called Number=22270888, Digit Strip=FALSE
   Calling Number=97688053(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pre
sentation=Allowed),
   Called Number=22270888(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=97688053, Final Destination Flag=TRUE,
   Guid=39F53AA8-F9AC-11E1-9C8B-0014A9CC7E2A, Outgoing Dial-peer=10
Sep  9 12:01:41.911: //870/39F53AA89C8B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=97688053
   ----- ccCallInfo IE subfields -----
   cisco-ani=97688053
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=22270888
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep  9 12:01:41.911: //870/39F53AA89C8B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B628DA0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=97688053,(Calling Name=)(TON=Unknown, NPI=Unknown,
Screening=User, Passed, Presentation=Allowed),
   Called Number=22270888(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10
, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
Sep  9 12:01:41.911: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep  9 12:01:41.911: :cc_get_feature_vsa malloc success
Sep  9 12:01:41.911:  cc_get_feature_vsa count is 2
Sep  9 12:01:41.911: :FEATURE_VSA attributes are: feature_name:0,feature_time:73
6553328,feature_id:750
Sep  9 12:01:41.911: //872/39F53AA89C8B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sep  9 12:01:41.911: //872/39F53AA89C8B/CCAPI/ccCallSetContext:
   Context=0x2A659EE0
Sep  9 12:01:41.911: //870/39F53AA89C8B/CCAPI/ccSaveDialpeerTag:
Sep  9 12:01:41.915: //872/39F53AA89C8B/CCAPI/cc_api_call_proceeding:
   Interface=0x2B628DA0, Progress Indication=NULL(0)
Sep  9 12:01:41.919: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=22270888, Called Number=22270888, Peer Info Type=DIALPEER_INFO
_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=22270888
   Result=Success(0) after DP_MATCH_DEST
Sep  9 12:01:41.919: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=22270888, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep  9 12:01:41.919: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20
     2: Dial-peer Tag=10
Sep  9 12:01:41.919: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=97688053, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=10
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Sep  9 12:01:41.923: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep  9 12:01:41.923: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep  9 12:01:41.923: //-1/39F53AA89C8B/DPM/dpAssociateIncomingPeerCore:
   Calling Number=97688053, Called Number=22270888, Voice-Interface=0x0,
Sep  9 12:01:41.923: //-1/39F53AA89C8B/DPM/dpMatchSafModulePlugin:
Sep  9 12:01:41.923: //-1/39F53AA89C8B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-ani=97688053
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=22270888
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep  9 12:01:41.923: //-1/39F53AA89C8B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B628DA0, Call Info(
   Calling Number=97688053,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=U
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T
RUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=873
Sep  9 12:01:41.923: //-1/39F53AA89C8B/CCAPI/ccCheckClipClir:
Sep  9 12:01:41.923: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global i
dentifier already present in the list of currently handled calls. It is being re
fused.
   SPI Call Setup Request Is Failed
Sep  9 12:01:41.927: //873/39F53AA89C8B/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x312F1FB8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 97688053
Called Number            : 22270888
Source IP Address (Sig  ): 10.101.6.18
Destn SIP Req Addr:Port  : 10.200.200.50:0
Destn SIP Resp Addr:Port : 10.200.200.50:5060
Destination Name         : 10.200.200.50
Sep  9 12:01:41.927: //873/39F53AA89C8B/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 8
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.101.6.18
Source IP Port    (Media): 28370
Destn  IP Address (Media): 10.101.6.18
Destn  IP Port    (Media): 22638
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 500
Sep  9 12:01:41.927: //872/39F53AA89C8B/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x2B628DA0, Call Id=872
   Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
Sep  9 12:01:41.927: //870/39F53AA89C8B/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Sep  9 12:01:41.931: //872/39F53AA89C8B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=872
Sep  9 12:01:41.931: //872/39F53AA89C8B/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=63)
   Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
Sep  9 12:01:41.931: //872/39F53AA89C8B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B628DA0, Tag=0x0, Call Id=872,
   Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
Sep  9 12:01:41.931: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  9 12:01:41.931: :cc_free_feature_vsa freeing 2BE6E968
Sep  9 12:01:41.931:  vsacount in free is 1
Sep  9 12:01:41.931: //872/39F53AA89C8B/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x312EC5C8
Destn SIP Req Addr:Port  : 10.200.200.50:5060
Sep  9 12:01:41.931: //872/39F53AA89C8B/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Source IP Port    (Media): 22638
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Disconnect Cause (CC)    : 63
Disconnect Cause (SIP)   : 503
Sep  9 12:01:41.931: //870/39F53AA89C8B/CCAPI/ccCallDisconnect:
ause=0)
Sep  9 12:01:41.935: //870/39F53AA89C8B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B628DA0, Tag=0x0, Call Id=870,
Sep  9 12:01:41.935: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  9 12:01:41.935: :cc_free_feature_vsa freeing 2BE6EA48
Sep  9 12:01:41.935:  vsacount in free is 0
Sep  9 12:01:41.935: //870/39F53AA89C8B/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x312E6BD8
Sep  9 12:01:41.935: //870/39F53AA89C8B/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Source IP Port    (Media): 18460
Destn  IP Address (Media): 10.200.200.253
Destn  IP Port    (Media): 17228
ARCH_ROUTER#
ARCH_ROUTER#
please i need help ASAP
thanks and regards
I can see a loop here...
fused.
Please reconfigure your gateway like this...If you still dont get ring back please send debug ccsip messages and debug voip ccapi inout
codec g711ulaw
no vad
dial-peer voice 21 voip
dtmf-relay rtp-nte
codec g711ulaw
no vad
Dear All
it is solved by Transcoding the codec between me and Telco company . thanks for all
