incoming calls ring to a dial tone
michaeljbyrne
uc 560
incomming calls to DID's ring to a dail tone
dial-peer voice 150 pots
  incoming called-number .T
direct-inward-dial
port
any ideas?
5 Replies 5
Brandon Buffin
What type of PSTN connection? PRI, POTS? If POTS, add the following to the voice port config:
voice-port 0/0/0
connection plar 100 (This will be the DN that you want incoming calls to ring to)
Hope this helps.
Brandon
PRI connection
Try changing the command to "incoming called-number ."
You can also run "debug voip dialpeer" to make sure that this dial peer is being matched on an incoming call.
Brandon
do you have any other pots dial-peer?
try "debug voip ccapi inout" to find which incoming dial-peer it is matching.
- abu
Walter Solano
Level 7
Level 7
Hello Michael.
Please try to change the "incoming called-number .t" to "incoming called-number .", another think that could be causing this issue its another dial-peer has been match as an incoming dial-peer please run a "debug voip CCAPI" when the call its coming into the system that will let us know which one its the true incoming dial-peer.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
