Incoming calls T1 CAS on SRST gateway. Phones doesn't ring and no codec.
sergiodovinte
I have a 2800 router connected trough VPN with a CallManager 4.2.
It has a T1 CAS configured and it works ok with MGCP.
My problem is when the connection between the router and the CM fails and the SRST mode is enabled.
If I call the T1 number I can hear the calling signal but none of the phones ring. It also shows Codec=None with the 'show active voice call status' command
Here is the router is on MGCP Fallback mode:
GW-S#sh ccm
MGCP Domain Name: GW-S.ccmdom.local
Priority        Status                   Host
Primary         Down                     CM1 (192.168.0.1)
First Backup    Down                     CM2 (192.168.0.2)
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            15:41:06 gmt Dec 2 2010 (elapsed time: 00:01:03)
Last MGCP traffic time:         15:40:36 gmt Dec 2 2010 (elapsed time: 00:01:33)
Last failover time:             15:41:08 gmt Dec 2 2010 from (192.168.70.1)
Last switchback time:           15:41:38 gmt Dec 2 2010 from (192.168.70.2)
Switchback mode:                Immediate
MGCP Fallback mode:             Enabled/ON
Last MGCP Fallback start time:  15:41:41 gmt Dec 2 2010
Last MGCP Fallback end time:    03:34:36 gmt Nov 30 2010
MGCP Download Tones:            Disabled
I call the T1's phone number and when the call is established the first thing I see on the router is this message:
*Dec  2 21:49:09.345: %CALL_CONTROL-6-APP_NOT_FOUND: Application mgcpapp in dial-peer 999010991 not found.  Handing callid 50 to the alternate app default.
With the call established ....
GW-S#sh voice call stat
CallID     CID  ccVdb      Port        DSP/Ch  Called #   Codec    Dial-peers
0x31       1247 0x48A411F4 0/1/0:1.1   0/1:1  *           None     999010991/-
GW-S#sh call active voice brief
<ID>: <CallID> <start>hs.<index> +<connect> pid:<peer_id> <dir> <addr> <state>
  dur hh:mm:ss tx:<packets>/<bytes> rx:<packets>/<bytes>
IP <ip>:<udp> rtt:<time>ms pl:<play>/<gap>ms lost:<lost>/<early>/<late>
  delay:<last>/<min>/<max>ms <codec>
media inactive detected:<y/n> media cntrl rcvd:<y/n> timestamp:<time>
long duration call detected:<y/n> long duration call duration :<sec> timestamp:<time>
  MODEMPASS <method> buf:<fills>/<drains> loss <overall%> <multipkt>/<corrected>
   last <buf event time>s dur:<Min>/<Max>s
FR <protocol> [int dlci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
  <codec> (payload size)
ATM <protocol> [int vpi/vci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
Tele <int> (callID) [channel_id] tx:<tot>/<v>/<fax>ms <codec> noise:<l> acom:<l> i/o:<l>/<l> dBm
  MODEMRELAY info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent> total:<rcvd>/<sent>/<drops>
         speeds(bps): local <rx>/<tx> remote <rx>/<tx>
Proxy <ip>:<audio udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3> endpt: <type>/<manf>
bw: <req>/<act> codec: <audio>/<video>
  tx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
rx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
124B : 50 270124840ms.1 +-1 pid:999010991 Answer  connected
dur 00:00:00 tx:0/0 rx:0/0
Tele 0/1/0:1 (50) [0/1/0.1] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
My configuration------------------------------------------------------------------
version 12.4
hostname GW-S
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-4.XC5.bin
boot-end-marker
card type t1 0 1
enable secret 5 $1$G4vy$iZ3bbI7Ru.c571aFhts641
no aaa new-model
resource policy
clock timezone gmt -6
network-clock-participate wic 1
network-clock-select 1 T1 0/1/0
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.7.1 192.168.1.2
ip dhcp pool Pool
   network 192.168.0.0 255.255.255.0
   option 150 ip 192.168.0.1 192.168.0.2
   default-router 192.168.1.1
   dns-server 192.168.0.1 192.168.0.2
   domain-name ccmdom.local
ip tftp source-interface GigabitEthernet0/0
no ip domain lookup
ip domain name ccmdom.local
ip host CM1 192.168.0.1
ip host CM2 192.168.0.2
ip ssh version 1
isdn switch-type primary-dms100
voice-card 0
no dspfarm
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
  call preserve
voice translation-rule 1
rule 1 /.*/ /2100/
voice translation-rule 2
rule 1 /^0/ //
voice translation-rule 20
rule 1 reject /981999999/
voice translation-profile Bloqueo_in
translate calling 20
voice translation-profile translate-in
translate called 1
voice translation-profile translate-out
translate called 2
application
global
  service alternate default
controller T1 0/1/0
framing sf
linecode ami
ds0-group 1 timeslots 1-24 type e&m-wink-start
description PRIMARIO
description INTERFAZ GATEWAY_1
duplex auto
speed auto
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager redundant-host CM2
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.0.1
ccm-manager config
mgcp
mgcp call-agent CM1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 800100 pots
service mgcpapp
port 0/0/1
dial-peer voice 999010991 pots
service mgcpapp
port 0/1/0:1
dial-peer voice 800000 pots
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-blind
ip source-address 192.168.1.1 port 2000
max-ephones 30
max-dn 20 dual-line
keepalive 120
time-format 24
date-format dd-mm-yy
Reading other posts I understand that my problem might be a bad dial-peer configuration. I've tried a lot of diferent configruations with the dial-peer but the result was the same. Any soul out there can help me?
MGCP doesn't work once the callmanager is down. The gateway acts likes a H323 device. You need to have additional dial peers configured to have that working
Hello Madhusudhan and thank you for your answer.
Yes, I already know that, I forgot to include theese peers on the configuration output:
dial-peer voice 8000 pots
description INCOMING T1 CAS Mode SRST
incoming called-number .
port 0/1/0:1
dial-peer voice 8001 pots
description OUTGOING T1 CAS Mode SRST
destination-pattern 0T
port 0/1/0:1
With those peers added the situation remains the same:
0x4B       126D 0x48A411F4 0/1/0:1.1   0/1:1  *           None    8000/-
1 active call found
: hs. + pid:
  dur hh:mm:ss tx:/ rx:/
IP : rtt:
  delay://ms
media inactive detected: media cntrl rcvd: timestamp:
long duration call detected: long duration call duration : timestamp:
  MODEMPASS buf:/ loss /
   last s dur:/s
FR [int dlci cid] vad: dtmf: seq:
  (payload size)
ATM [int vpi/vci cid] vad: dtmf: seq:
  (payload size)
Tele (callID) [channel_id] tx://ms noise: acom: i/o:/ dBm
  MODEMRELAY info:// xid:/ total://
         speeds(bps): local / remote /
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
1271 : 76 337667170ms.1 +-1 pid:8000 Answer  connected
Tele 0/1/0:1 (76) [0/1/0.1] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
Finally I've solved the problem.
rule 1 /.*/ /2100/
That rule pointed to 2100, that's a Hunt Pilot created in the CallManager.
While in SRST mode, CallManager is not accesible, so the router can't reach that 2100 group.
I created "alias" into the Call-Manager-Fallback section so I can emulate the 2100.
