Inconsistent CMC
Dear Folks, I am restricting few conf phones with Client Matter Codes... Why is the CMC is not consistent... With all the configs done... Route patter --> Client Matter Codes and the relevant CSS.... It works for the first time and stops working for the second time and takes the line through without prompting CMC. It's kind of inconsistent.. when I make a change and save and force a reset of the Route List and associated gateway and it starts working Please help..
Jaime Valencia
What CUCM version, and does this only happen to conference phones??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
The version is 8.6.2 and it happens with every other model too...
Hello.. Does any one have come across the above scanario for CMC's being inconsistent....? Pls share any help... Thanks
