Incorrect time on Ip phones
Hi all,
Today i was migrating some Ip phones in  my office to a new CUCM, these phones while registered with the previous CUCM displayed the correct time, when I migrated them to the new CUCM(this CUCM already haves 250+ ip phones registered with correct time displayed) the currently migrated phones are displaying the wrong time, i have configured the vlan correctly as well.
Can someone help me on this to where to check for this thing??
9 Replies 9
Rajan
Try deleting the ITL files on one phone to see if that helps.
Rajan
and how can i do that?
https://www.variphy.com/kb/delete-itl-file-on-cisco-7945-or-7965-ip-phone
It did nit worked, I deleted it.
What is the phone model and current firmware version ?
Do you see any messages in Settings --> status messages on the phone ?
Phone models are 7961,7962,7975 all are SCCP phones
Load file for 7961 is SCCP41.8-3-2S
Hi Zaheer,
Was the issue with your NTP or the phone firmware?
Safdar Azizi
Please cross verify the phone configuration whether the phone is picking the new cucm ip.
Also , you may try doing factory reset on a phone .
Safdar
Best wishes,
Safdar
The phones are getting te new CUCM IP as well and factory reset did not helped even
