12-28-2012 05:20 AM - edited 03-16-2019 02:54 PM
We have inegrated CM with CME and this works.
How can we pass the names from CM to CME and the otherway around?
At this moment only the number is shown.
JH
Solved! Go to Solution.
12-28-2012 06:03 AM
Have you added the ccme gateway as an h323 gateway? If you have scroll down to gateway properties and check the box "display ie deliver"
Sent from Cisco Technical Support Android App
12-28-2012 05:23 AM
Check CM config in gateway properties.
12-28-2012 06:03 AM
12-28-2012 06:10 AM
Yes I forgot the IE delivery.
JH
