05-06-2015 05:46 AM - edited 03-17-2019 02:54 AM
I am getting below errors intermittently. This problem happens sometimes once in a day and sometime two times a day.
I have attached the voice gateways configuration, isdn debug and output of E1 card as a reference. I spoke with Telco guys but as per them there is no issue from their side.
Cause i = 0x80E6 - Recovery on timer expiry
Cause i = 0x80E20D - Message not compatible with call state or not implemented
Output of Debug ISDN Q931
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98392
Exclusive, Channel 18
Calling Party Number i = 0x0081, '043749317'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0079618448428'
000705: *May 6 08:11:29.124: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8ADF
000706: *May 6 08:11:32.072: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8AB9
000707: *May 6 08:11:32.080: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 043648682
000708: *May 6 08:11:32.084: ISDN Se0/0/1:15 Q931: Sending SETUP callref = 0x0AE0 callID = 0x8CA9 switch = primary-net5 interface = User
000709: *May 6 08:11:32.084: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0AE0
Standard = CCITT
Channel ID i = 0xA98381
Calling Party Number i = 0x0081, '043648682'
Called Party Number i = 0x80, '0077015118998'
000710: *May 6 08:11:32.084: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0AE0
000711: *May 6 08:11:32.096: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8AE0
000712: *May 6 08:11:32.096: ISDN Se0/0/1:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8CA9, call ref 0xAE0, event 0xD
000713: *May 6 08:11:32.096: ISDN Se0/0/1:15 Q931: TX -> STATUS pd = 8 callref = 0x0AE0
Call State i = 0x0B
000714: *May 6 08:11:32.100: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x8AE0
000715: *May 6 08:11:32.100: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0AE0
000716: *May 6 08:11:32.124: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8ADF
000717: *May 6 08:11:33.640: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8ABB
000718: *May 6 08:11:33.648: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 044387486
000719: *May 6 08:11:33.648: ISDN Se0/0/1:15 Q931: Sending SETUP callref = 0x0AE1 callID = 0x8CAA switch = primary-net5 interface = User
000720: *May 6 08:11:33.648: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0AE1
Standard = CCITT
Calling Party Number i = 0x0081, '044387486'
Called Party Number i = 0x80, '0079122597976'
000721: *May 6 08:11:33.656: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0AE1
000722: *May 6 08:11:33.664: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8AE1
000723: *May 6 08:11:33.668: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x8AE1
000724: *May 6 08:11:33.668: ISDN Se0/0/1:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8CAA, call ref 0xAE1, event 0xD
000725: *May 6 08:11:33.668: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 044550227
000726: *May 6 08:11:33.668: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0AE2 callID = 0x8CAB switch = primary-net5 interface = User
000727: *May 6 08:11:33.668: ISDN Se0/0/1:15 Q931: TX -> STATUS pd = 8 callref = 0x0AE1
Call State i = 0x0B
000728: *May 6 08:11:33.668: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0AE1
Output of show controllers E1
voice-gateway#sh controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (554 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 18 15 minute intervals):
179 Line Code Violations, 24 Path Code Violations,
1 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins,
7 Errored Secs, 5 Bursty Err Secs, 0 Severely Err Secs, 100 Unavail Secs
E1 0/0/1 is up.
No alarms detected.
12 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
12 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
315 Line Code Violations, 16 Path Code Violations,
352 Slip Secs, 0 Fr Loss Secs, 5 Line Err Secs, 0 Degraded Mins,
358 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 110 Unavail Secs
E1 0/1/0 is down.
Transmitter is sending remote alarm.
Receiver has loss of signal.
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 554 Unavail Secs
1541 Line Code Violations, 33 Path Code Violations,
161 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
161 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 1655 Unavail Secs
05-06-2015 05:54 AM
I see that all the errors in the above output relate to ISDN Se0/0/1:15. Have you noticed that the errors you receive are only referring to this port alone? If so, have you tried moving the cable from this port and putting it in a different port to see if the error follows it. If the error follows the move to another port, it is likely a problem with the ISDN Provider. If the errors stay on the same port then it would be a config or hardware issue.
05-06-2015 05:59 AM
Hi Robert Shaw,
We have three PRIs and when the issue happens users wont be able to make outgoing calls, sometimes there is a delay and sometimes it gives fast busy tone.
I have attached the sample output. I have seen the same errors on all the other PRIs and different channels.
05-06-2015 06:33 AM
Which country are these installed in? It looks like a Line Code or framing issue, suggested by your show controllers e1 output. Normally the default framing is CRC4, whereas you have specifically configured No CRC4.
Rob
05-06-2015 06:44 AM
Hi Robert,
I have confirmed with Telco they has disabled the CRC4, so it should be NO-CRC4.
We follow European standard and we are located in Dubai, United Arab Emirates.
I am still not able to understand the full meaning of the below two ISDN Errors.
Its very strange that the same configuration works fine most of the time and when the issue occurs it does not work and this issue automatically get resolve.
I believe this issue is from the Telco side but Telco guys are not co-operative. I have requested them to share the output of E1 Controllers but still no luck.
05-06-2015 07:17 AM
I'm more concerned by the Line Code and Path Code violations.
Line Code Violations occur with an incorrect Line Code specified in the Controller Config. There are only two options for this and the default is HDB3 which you have set, I have never seen anyone use AMI on an E1 circuit. You could of course try it.
The Path Code Violations are framing issues, you have confirmed with the Telco that they use NO CRC4, so your config there is also correct.
I would clear the controllers to reset the counters with "clear controllers e1 0 0" etc. Then repeatedly run sh controllers e1 making a note each time of the Line code and Path code violations. If they continue to increase then the problem is related to the Telco.
If one thing is standard all over the world the Telco will always tell you that the problem is not theirs.
Rob
