IOS Conference Bridge and CCM 5.1..Error DB Config
Ayodeji Okanlawon
I am trying to setup an IOS enhanced conference bridge using cisco 2821 router with ccm 5.1(2).
Status of the Transcoder and Conference bridge shows registration rejected.
When I did a debug sccp all...I get this erro message...*Dec 20 10:42:03.953: sccp_parse_control_msg: rcvd register rej, reason: Error: DB Config*
I observed that my router IOS does not support 5.1 beacsue when I try to use this command....
sccp ccm 10.20.X.X identifier 2 version ?
I can only see support upto ccm 4.1.
Is this the problem? Do I need to upgrade my IOS.
Thanks..
Attached is my debug sccp and sh run command
Please rate all useful posts
5 Replies 5
Chris Deren
You do not need to upgrade the router, however you will need to include the version 4.1 line in the configuration. The it will register and work just fine.
HTH,
Chris
thanks. It worked.
Hi, have same problem.
Can't initiate SCCP connection between CCM 5.1 and C2801.
Get same error:
*Feb 14 14:55:28.170: sccp_parse_control_msg: rcvd register rej, reason: Error: DB Config
I tried your solution with, but doensn't help:
sccp ccm 192.168.200.200 identifier 1 priority 1 version 4.1
CCM is:
admin:show version active
Active Master Version: 5.1.3.1109-1
Cisco routerSW s:
Cisco IOS Software, 2801 Software (C2801-IPVOICEK9-M), Version 12.4(25f), RELEASE SOFTWARE (fc2)
Hardware:
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801         , VID: NA  , SN: FCZ091322EG
NAME: "WIC/VIC 2", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 33229705
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: NA  , SN: FOC09044PFS
Router configuration is attached.
Debug log is aslo attached.
In your router config you have the line:-
associate profile 1 register 136085bfa6
The key here is 136085bfa6
This must be the same as the device name in the CUCM CFB config page
Please check
Alex
Regards, Alex. Please rate useful posts.
Some more digg in CCM ant we found the string you're write about.
Now the strings are the same and everything is working properly.
Thanks a lot!
Jevgenij
