07-14-2020 02:15 PM
I have a Cisco IP 8851 that is not Ringing. Even when you hit volume up or down to set ring volume you do not hear a audible ring like on other phones. All CUCM 11.5 settings look right such as “device ring”. Any ideas?
Solved! Go to Solution.
08-10-2020 12:12 PM
07-14-2020 11:30 PM
Hello Brian,
Can you check under "Directory Number Configuration" -> "Line 1 on Device XXXXX" that the Ring Setting (on Phone Idle) is set to "Ring" (if this is not the default option in your implementation).
George
07-15-2020 05:15 AM
07-15-2020 05:38 AM
Could you change it to ring to check if it makes any difference?
08-10-2020 12:12 PM
