IP COMMUNICATOR 7 hangs on Registering
Hi All
I am not a too much cisco expert and i would like some assistance on this problem.
I have setup a UC540 voice with 10 cisco ip phones in a client's office and everything work fine.
However i cant get the IP Softphone to work from the manager's laptop at home.
I can succesfully connect from his laptop to another voice system i have setup in the past and it works ok.
When i establish the vpn connection with the cisco vpn client i can see that i have complete access on the remote network. When i start the ip communicator it says registering and it hangs there.
Is there some sort of debugging or logging i can do to find out the problem?
11 Replies 11
paolo bevilacqua
You VPN is not setup right, or CIPC is not configured right.
I can ping and connect on the CME router from my laptop. I have checked the routing table and everything seems ok.
I have recreated the CIPC ephone but still no luck
If i change the tftp server on the ip communicator preferences and put something completely different it popus an error message saying wrong tftp server.
Is there any sort of debugging i can do to trace the source of the problem?
What is the EPHONE mac address you are using.   I usually set it to use 1 mac address at all times.  I sometime see that people have a 1 mac when connected from one place, and another mac when connected from another place.  I would hard code the CIPC to use the same mac address no matter how its connected.
As for debugging you can do a debug tftp events, term mon to find out if the phone is making it back to your UC500 system.
Rejohn Cuares
Level 4
Level 4
Could you post your CME configuration for CIPC and screenshot of the CIPC's network settings?
Please rate replies and mark question as "answered" if applicable.
debug tftp events doesnt show anything
Here is a part of the CME config
Below is a screenshot of the network settings on the ip communicator and last the mac address of the laptop i am using.
ip inspect name ACL_OUT dns
ip inspect name ACL_OUT ftp
ip inspect name ACL_OUT h323
ip inspect name ACL_OUT https
ip inspect name ACL_OUT icmp
ip inspect name ACL_OUT imap
ip inspect name ACL_OUT pop3
ip inspect name ACL_OUT tftp
ip inspect name ACL_OUT tcp router-traffic
ip inspect name ACL_OUT udp router-traffic
ip inspect name ACL_OUT sip
ip inspect name ACL_OUT sip-tls
ip inspect name ACL_OUT ssh
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 192.168.1.120 217.27.32.196
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key xxxxxxxxx
dns 217.27.32.196
pool SDM_POOL_1
acl VPN
save-password
max-users 10
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
interface FastEthernet0/0
ip address 46.21.56.193 255.255.255.248
ip access-group INBOUND in
ip nat outside
ip inspect ACL_OUT out
ip virtual-reassembly in
duplex auto
speed auto
interface BVI1
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip local pool SDM_POOL_1 192.168.60.15 192.168.60.25
ip access-list extended INBOUND
permit tcp any any eq 2000
permit tcp any any established
permit tcp any any eq 3390
permit tcp any any eq 3389
permit gre any any
permit tcp any any eq 1723
permit tcp any any eq smtp
permit tcp any any eq 443
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit esp any any
deny   ip any any log
ip access-list extended VPN
permit ip 192.168.1.0 0.0.0.255 any
permit ip 10.1.1.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 192.168.60.0 0.0.0.255
permit ip 10.1.1.0 0.0.0.255 192.168.60.0 0.0.0.255
ephone-dn  5
number 565
label SOFTPHONE 565
description SOFTPHONE 565
name SOFTPHONE
hold-alert 30 originator
ephone  1
device-security-mode none
mac-address 001A.4B6B.C5C4
type CIPC
button  1:5
Could you do this for me?
1. Make your Primary TFTP server IP as 10.1.1.1 and leave Secondary TFTP server empty.
- OR -
I encountered an issue in CIPC v2.x wherein I need to configure both Primary and Secondary TFTP server IPs to same IP address, in your case this will be 10.1.1.1. This is worth trying.
2. Under the Device Name use the option USE THIS DEVICE NAME and enter 001A4B6BC5C4.
Just tried your above suggestions but still no luck
I think the problem is that the vpn pool 192.168.60.0 is being blocked from accessing the 192.168.1.0 or 10.1.1.0 network.
Windows firewall is off . i have no other network security or antivirus security on the laptop.
Howerver as i said, from the same laptop  i can succesfully connect on another 2900 series router running CME and the CIPC works just fine.
It will drive me crazy
EzVPN client bypasses the inbound ACL configured under interface FastEthernet0/0. You also stated in your first post
"When i establish the vpn connection with the cisco vpn client i can see that i have complete access on the remote network."
To make sure this is true, connect to the VPN and telnet CME IP address on port 2000 (considering your using the defaut port under the Telephony-service).
Yes you are right. actually i meant that i can access all resouces from the windows laptop throught the vpn but something might blocking the CIPC from accessing the remote resources and since the CIPC gets the vpn-pool ip address thats why i made this thought but it was a silly thought.
Ok i telnet 192.168.1.1 2000 and 10.1.1.1 2000 and then i had a blank screen which means i suppose that i can succesfully telnet.
The new strange thing i found out yesterday is that i have exactly the same problem when i am tring to connect on another uc540 on a different customer side. since now this customer hasn't asked me to setup a softphone for him but i have set it up last night and i am facing the same issue. Could it be a compatibility issue between windows 7 , CIPC ver 7.0.6.0,cisco vpn client 5.0.07 64bit and uc540 with software pack 8.1?
I have just used a laptop running windows xp 32 bit and the CIPC worked immediatelly!!
I think the problem is due to compatibility
Good to hear you resolved your issue.
I recommend using Cisco AnyConnect VPN for 64bit machine.
