Showing results forĀ
Search instead forĀ
Did you mean:Ā
cant make international conference call on Cisco phone by putting conference code
amralrazzaz
Level 5
Level 5
hi
i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation
i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference code , so the local answer machine (Egypt) said this number is wrong please check number .etc
why i cant put the conference code to join the call and  the local answer machine reply this number is number and the international call is already on hold waiting for conference code to join
Note: i dont have landline , im using Vodafone sim card on our ip central system because we dont have landline infra and boxes in our building
thanks
amr alrazzaz
Hi there
Could you try the commands with tftp alias
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern2.78xx.12-1-1-12.sbn
Create profile and reboot the phone
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
71 Replies 71
j.huizinga
Level 6
Level 6
Not really understand what you mean with "local answer machine" I assume you dial an international number, the remote party asks for access PIN and then you conference. When DTMF is not working correctly, then normally it is a DTMF issue / misconfiguration
Is the CME or CUCM?
JH
yes exactly as u said im receiving invitation meeting with conference number with conference code
i dial the international conference number then it ask for code to join the meeting
once i inter the code number its not accepting , its like the device take the code as a number and then it said wrong number (seems like i dial number normally and its wrong)
and the line for the international number i dialed  is already active online
amr alrazzaz
im using cme
amr alrazzaz
this is sample of configuration for one phone
voice register dn 7
number 102
name Walid Hifny
label Walid Hifny
mwi
mobility
voice register pool 7
busy-trigger-per-button 1
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
amr alrazzaz
this configuration for one phone
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing manager
destination-pattern 900T
prefix 00
dial-peer voice 12 pots
prefix 00
should i add on international call under voice pots
dtmf-relay rtp-nte
amr alrazzaz
dtmf-relay are only for voip dial-peers
You can try under voice register pool: dtmf-relay sip-kpml sip-notify
JH
i already configured for all phones under voice pool register dtmf-relay rtp-nte
what difference between dtmf-relay rtp-nte and  dtmf-relay sip-kpml sip-notify ?
also jut to inform after dialling the international call and asked me for conference call (ex : 40903909029ā™Æ)
then the local answer machine of my local line says this number is wrong ) so i cant complete the process to join the conference
amr alrazzaz
Rather than just making changes, let's see what is really happening. What is your call flow like ?
IP Phone >> CME >> ?? PSTN
How is your CME communicating with your PSTN/ITSP ? PRI/FXO/SIP ? Depending upon this we can take some logs and see why is the DTMF being messed up.
yes sure
find attached drawing
i have cisco 2911 with 2 i/f card each 4 fxo port (total 8 fxo)
using 2 port fxo connected to primacell devices each one has attached with sim card from vodafone
and switch 24 port 2960 giga port all devices connected to ip phones and ip phone connected to our laptops
we dont have on our buildings landlines infra
thanks
amr alrazzaz
Thanks for the share. So, where are having issues ? Over FXO ? I also see that your GIG is connected to another router GIG which you have marked as ISP. What is that for ?
this is an isp router just connected to our office router its internet service only from isp
but now about the call i can call international but cant put the conference code after asked for that followed by hash , the phone didn't recognize that its code not a number
thats why local line vendor answer machine said this number is wrong please try another
thanks
amr alrazzaz
Can you please post the output of a debug ccsip messages while trying to access the conference bridge?
Carlo
Please rate all helpful posts "The more you help the more you learn"
no output during calling ???
amr alrazzaz
problem is again
have number to call : 0031207965365
conference code : 4070564832#
i can call number the asking for conference code , when i type its not appearing on screen that there is digits i typed and my subscription answer machine said this is wrong number plz try correct one , that mean cisco phone didnt recognize that 2nd digits is a conference code not a number
thanks
amr alrazzaz
