IP Communicator question
rramlal
Hi all,
I have a scenario where an ip communicator will be connecting via their wireless card over at a subsite however my question is if this laptop plugs into for instance a head office location using their LAN card instead, how can I make that work? Is there a particular mac-address that can allow this for me?
Thanks much.
Chris Deren
With IPC you can use any device name you want, a good practice is to not use the MAC address but rather define a device name on IPC, this way you don't have to worry about which interface on the laptop is used as it will always use the defined device name to register.
HTH,
Chris
Chris Deren
HTH,
Chris
Wow I didnt know this. Is there any specification for the device name? Can you give an example?
There is a limit on how many characters can be used, if I recall it is 12, so I like to use naming convention such as IPC as long as that does not exceed the limit.  To validate the limit, see how many characters you can use as device name on IPC device in CUCM.
HTH,
Chris
Thanks much for the fast response on this.
