Ip phone 7821 licensing issue
Hello engineers!
I have fifteen ip phones 7821 model but I only could register 5 of them, the rest give me the "unknown" message. I have understood that this phones need UCL basic license.
My question is, that if I have some enhanced UCL licenses available, could this phones take this enhanced licenses in order to registering in the CUCM?
I have 9.1.2 CUCM version.
Actually, I have the next licensing:
Thanks for your help!
Regards!
Iván
21 Replies 21
George Thomas
Level 10
Level 10
If you have spare Enhanced or higher licenses, basic licenses will borrow from that pool. I dont think the 7821 not registering is related to your licenses, something else might be going on.
Please rate useful posts.
Hi Ivan,
[+5] to friend George.
I think you are hitting the two bugs related to your issue.
7821 phones consume Enhanced UCL instead of Basic in CUCM 9.x and 10.x
CSCun94112
Symptom:
License usage
Conditions:
7821 phones consume Enhanced UCL instead of Basic - in CUCM 9.x and 10.x
CSCun03177
Symptom:
For 9.x:
Adding a 7821 phone takes up an "Enhanced" license - contradictory to documentation which says it should be a "Basic" license.
For 10.x:
Issue 1: when adding phone, it shows as 1 license ENHANCED, not Basic (like documentation says)
Issue 2: when adding user to new phone, it disappears as a license completely
Conditions:
Must upgrade 9.1.2 using the cmterm-devicepack9.1.2.12024-1.cop.sgn so that the 7821 phone shows up.
Must upgrade 10.x using the UCSInstall_UCOS_10.0.1.11001-2.sgn to resolve issue #2 for CUCM 10.x
Workaround:
Please contact Cisco TAC so they can perform the workaround on the impacted system
regds,
aman
Thank you very much Aman
So, is not possible that 7821 phones take enhanced licenses? Even if I do not have enough basic licenses, but I have enough enhanced licenses?
Regards!
Iván
Hi Ivan,
Can u share the complete snapshot of Table View which shows Status/Unused as well?
Also,please share the Chart View and keep the mouse on Purple Colour if it appears  which Licenses borrowed from Upper Tier
regds,
aman
Hi Ivan ,
Sorry, I missed the attachment.I can also see you have got 14 unused licenses under Enhanced.
Did u run Synchronise Now?
regds,
aman
Hi Aman.
Yeah I have 14 unused enhanced licenses, but I have not run Synchronise Now, do I need to run this?
Regards!
Iván
Hi Ivan,
please do that .
regds,
aman
Thank you George
Right now I am doing more troubleshooting, because we have enough enhanced licenses available.
I'll inform you.
Thanawee Buntho
we are facing the same issue.
as I checked in firmware release note. 10.1(1) SR1
this Bug is wait for new divice pack.
CSCun03177
7821 phones consume Enhanced UCL instead of Basic - in CUCM 9.x and 10.x.
Note    The fix for this defect will be available with the next device pack.
have u installed any Device pack?
can u share show version active ?
regds,
aman
This is a bug in cisco and I have opened TAC case as soon as its done i will post how to resolve.
Currently TAC wants to access the root :).
thanks for same.please do share the findings of TAC.
regds,
aman
Cisco confirmed that there is a problem in 9.x version and it has been resolved in 10.X latest version.
Since I have some licensing issues we sticked to the same version which is
9.1(2.11012) instead upgrading it to version 10.x
Step) The engineer asked us upgrade the latest device pack codec which is
Cisco Unified Communications Manager 9.1(2.12033) Device Package - Compatible UCM Version: 9.1
http://software.cisco.com/download/release.html?mdfid=284510097&flowid=45900&softwareid=282074299&release=9.1(2.12033)&relind=AVAILABLE&rellifecycle=&reltype=latest
Step2) Asked us to create the root access user with the below commands
utils remote_account enable (This will enable the remote account to be able to log on to the root)
utils remote_account create ciscotac 30 (This will create a new user called ciscotac and 30 is the number of days the the username will be valid )
utils remote_account status ( To show the user has been created)
http://docwiki.cisco.com/wiki/Enabling_root_account_from_CLI
Note: The password of the ciscotac user created is with the TAC engineer and they refused to give me upon asking they told its internally generated wit the hardware id .
Note: If you dont have TAC assistance you can still log on to root with the below steps mentioned, also please do it own risk :)
How ever here is the work around  once the user is created restart the server.
admin:utils system restart
-Proceed to insert the CentOS 5.2 Disk 1
-on the Boot option enter linux rescue(or press f12)
boot:linux rescue
-Once you are in Linux shell proceed to do the following:
chroot /mnt/sysimage
cd /etc
rm securetty (removes file protection)
chattr -i passwd (gain access to file system file.. (bascially))
chattr -i shadow (gain access to file system file.. (bascially))
passwd ciscotac
Enter a password for this account. Before proceeding note that the password change was successfull, if authentication fail you probably missed the earlier steps.
Remove CentOS disc and restart server, when fully booted log in with ciscotac
account and the password you just configured in rescue mode.
If login successfull you should be seeing:
Welcome to Remote Support :).
Step 3) Logon with the credentials to the cucm using the putty ssh client.
root@CMPUB:/home/ciscotac[root@CMPUB ciscotac]# su informix  (Press Enter)
Step 4)
bash-3.2$ dbaccess (Press Enter)
After pressing  a menu will appear and select your data base
in my case it was below mentioned which is actually reflects the installed version on cucm
ccm9_1_2_10000_12 -
Step 5)
dbaccess ccm9_1_2_10000_12 -  (Press Enter)
Database selected.
Step 6)
update typelicensedresourceproductmap set tklicensedresource='2' where tkproduct='508';
We are done :).
If you have more questions we can discuss over here to help the community. please feel free to ask me .
thanks for sharing the info[+5]
So,now licenses being consumed are OK[basic]
regds,
aman
