IP Phone 7945 Not registering
cleetusant
Hello
Cisco 7945 Phone is keep on "Registering"
IP phone gets correct IP details including tftp IP address
I have attached the debug tftp events and packets output.
Can any one give me a lead on this please.
Cleetus
Run the following commands under telephony-service -
tftp-location flash:
cnf-file perphone
no create cnf
create cnf
Check if the flash has the correct SEP file or not.
If the phone still does not register, take a log for the following -
debug tftp packets
debug tftp event
debug ip tcp transactions
12 Replies 12
R0g22
The phone is requesting for a signed config file -
Looking for SEP0008303167E2.cnf.xml.sgn
If you are not using a secure CME, then you need to delete the CTL/ITL files from the phones.
How can I delete those ?
I could delete.
Still same .. Keep on registering.
What do you see in the TFTP logs now ?
*Feb 26 14:09:36.303: TFTP: Server request for port 50894, socket_id 0x4A8464F0 for process 390
*Feb 26 14:09:36.303: TFTP: read request from host 192.168.20.6(50894) via GigabitEthernet0/1.20
*Feb 26 14:09:36.303: TFTP: Looking for CTLSEP64AE0C5F7783.tlv
*Feb 26 14:09:36.303: TFTP: Sending error 1 No such file
*Feb 26 14:09:36.375: TFTP: Server request for port 52098, socket_id 0x4A8464F0 for process 390
*Feb 26 14:09:36.375: TFTP: read request from host 192.168.20.6(52098) via GigabitEthernet0/1.20
*Feb 26 14:09:36.379: TFTP: Looking for ITLSEP64AE0C5F7783.tlv
*Feb 26 14:09:36.379: TFTP: Sending error 1 No such file
*Feb 26 14:09:36.447: TFTP: Server request for port 50796, socket_id 0x4A8464F0 for process 390
*Feb 26 14:09:36.447: TFTP: read request from host 192.168.20.6(50796) via GigabitEthernet0/1.20
*Feb 26 14:09:36.447: TFTP: Looking for ITLFile.tlv
*Feb 26 14:09:36.447: TFTP: Sending error 1 No such file
*Feb 26 14:09:36.607: TFTP: Server request for port 49163, socket_id 0x4A8464F0 for process 390
*Feb 26 14:09:36.607: TFTP: read request from host 192.168.20.6(49163) via GigabitEthernet0/1.20
*Feb 26 14:09:36.607: TFTP: Looking for SEP64AE0C5F7783.cnf.xml
*Feb 26 14:09:36.607: TFTP: Opened system:/its/vrf1/XMLDefault7945.cnf.xml, fd 10, size 0 for process 390
*Feb 26 14:09:36.607: TFTP: Sending block 1 (retry 0), socket_id 0x4A8464F0
*Feb 26 14:09:36.611: TFTP: Received ACK for block 1, socket_id 0x4A8464F0
*Feb 26 14:09:36.611: TFTP: Finished system:/its/vrf1/XMLDefault7945.cnf.xml, time 00:00:00 for process 390
Do you have the ephone configured or are you trying to auto-register this ?
ephone 1
device-security-mode none
mac-address xxxxxxxxx
type 7495
button 1:1
configured like this
cnf-file perphone
no create cnf
create cnf
debug tftp packets
debug tftp event
Thanks Nipun
It worked.
It was all about the cnf files creation
Thanks again
Cleetus
Awesome!
I am also facing issue with cisco 7945g registration. We upgraded the phone with sip firmware & later realised we cannot configure sip directly on phone or web. So i had to create sepmac.cnf.xml file & put all sip details in there , i am trying it to connect with one of the third part cloud pbx but unable to register,  aftrr waited for long , lines have red x please help,,,i am not expert , by doing r n d online i have done this so far
