11-07-2023
05:55 AM
- last edited on
11-07-2023
06:04 AM
by
rupeshah
Solved! Go to Solution.
01-01-2024 06:08 AM
Dears hope you are will
i solved my problem and make integration with issabel the issue was in xml file
11-07-2023 07:35 AM
A few questions:
Let us know so we can better help.
Maren
11-08-2023 02:11 AM
I have Issabel 4.0.0-9 , How can i checking that ( Is the phone provisioned by MAC in CUCM) , If the phone is provisioned in CUCM and is a SIP phone, is a directory number configured on the phone No ,
status Massage
10:41:28a File Not Found : ram/SEP0024142DD25B.cnf.xml | |
10:41:28a File Not Found : SEP0024142DD25B.cnf.xml | |
10:41:28a XMLDefault.cnf.xml | |
10:42:04a No IPv4 DNS Server | |
10:42:04a No IPv6 DNS Server | |
10:42:04a No IPv6 TFTP Server | |
10:42:04a No Trust List Installed | |
10:42:05a File Not Found : ram/SEP0024142DD25B.cnf.xml | |
10:42:05a File Not Found : SEP0024142DD25B.cnf.xml | |
10:42:05a XMLDefault.cnf.xml |
11-07-2023 07:36 AM - edited 11-07-2023 07:36 AM
Hello @waleed easyvision ;
Cisco router CME or CUCM as call center ? Which Firmware ? SIP or SCCP ?
Do you debug TFTP events to see the issue ? Do you have log on phone ?
11-08-2023 02:15 AM
I have Issabel 4.0.0-9 , VM , Firmware 9.2.1 , SIP , No debug TFTP Event appear , No I don't
11-08-2023 03:04 AM
As you seem to use a 3:rd party calling system, Issabel 4.0.0-9 from what you wrote, this forum is not the appropriate place to ask for help. If you do use a Cisco calling system, like Communication Manager (CM) or Commutation Manager Express (CME), then we can help you with your questions.
11-08-2023 07:16 AM
In addition to what @Roger Kallberg said, the firmware on a Cisco 7975 phone will use Cisco proprietary signaling to connect to CUCM. Unless Issabel accepts this signaling natively you will not get the Cisco phone to register to Issabel. However, there is a SIP-Only (basic SIP functionality) version of the 7975 firmware that might allow it to register as a simple SIP device but I don't think that firmware is still available for download from Cisco's website.
Maren
01-01-2024 06:08 AM
01-01-2024 06:12 AM
Perfect @waleed easyvision
Thanks for your feedback.
