02-17-2017 06:25 AM - edited 03-17-2019 09:33 AM
after mute lit ,it did not enter reset progress, after cisco logo, it displays "big easy diagnostics", someone know about this?
02-17-2017 07:38 AM
Plug it in a dhcp enabled switch port with Option 150 pointing to correct TFTP and perform a factory reset as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series/P881_BK_C136782F_00_cisco-ip-phone-8811-8841_chapter_01111.html#task_D1FE4AF0D3C84DE16C2C560EAA02EFDA
If the issue persists then phone would require a replacement.
Manish
02-19-2017 05:42 PM
it seems that the phone did not connect to the network
