04-24-2017 01:38 AM - edited 03-17-2019 10:08 AM
My call manager version is 8.6.2
I have 7 location ,one location I couldn't change clock ,When I changed clock on the device pool,there is no change on the phone
thanks
04-24-2017 02:38 AM
Which phone models are involved, are they running SIP or SCCP, is the NTP reference set correctly , is the phone pulling the new config file post reset? You may try restarting the TFTP service and then resetting the phones.
Manish
04-24-2017 05:08 AM
ı restarted the tftp service and reset the phone but there is no change
