Showing results forĀ
Search instead forĀ
Did you mean:Ā
Ip phone couldn't change clock problem
ozden ozdugun
My call manager version is 8.6.2
I have 7 location ,one location I couldn't change clock ,When I changed clock on the device pool,there is no change on the phone
thanks
Manish Gogna
Which phone models are involved, are they running SIP or SCCP, is the NTP reference set correctly , is the phone pulling the new config file post reset? You may try restarting the TFTP service and then resetting the phones.
Manish
ı restarted the tftp service and reset the phone but there is no change
