IP Phone Extension cannot be direct Dialed
Cathy Adams
I am using CUCM 6.1.4.1000-10.  All of my phone extensions can be direct dialed (ie: (acode)-266-nnnn where nnnn is the extension or directory number)
I am having an issue with on of the extensions.  When I dial it directly,  it gives me a busy signal.   Where in the CUCM should I start looking to correct this??
Cathy
Rob Huffman
Hi Cathy,
I think the simplest thing to do would be to remove the
DN from the phone or remove the phone completely, then go
to Call Routing > Route Plan Report > Unassigned DN's and
remove the DN in question. Then reset up the number/phone etc.
and retest
Cheers!
Rob
Rob Huffman
Hi Cathy,
and retest
Cheers!
Rob
Thanks so much Rob for your quick response..  good idea..  I will do that.  Probably a  lot faster than trying to resolve what caused this anyway.
Have a fantastic weekend..
Cathy
