IP phone is not registering on CUCM with SRST
Jean Lofrano
My ip phone register with Router SRST, but the CUCM cannot to register the same ip phone...
- SRST was created with the ip 10.100.5.1 (IP of the remote router)
- Trunk h323 is working with device pool SRST
- device phone is with device pool SRST
I have a 2801  with:
telephony-service
 srst mode auto-provision all
max-ephones 30
ip source-address 10.100.5.1 port 2000 (IP address of the my local interface)
ephone-dn 1 dual-line
number 2970
 name 2970
 description 2970
ephone 1
 mac-address 0112.80B3.9C16
 button 1:1
 type 7912
Jean Lofrano
The network is ok...
The router and switch "ping" the CUCM
CUCM "ping" without problems the router and switch
Chris Deren
Can you post your entire "telephony-service" config?
Do you have "max-dn" command under it?
Alos, when you browse to the IP address of the phone do you see the SRST IP address as one of the CM servers referenced?
Chris
Hello Chris,
I put the "ip helper addres" in the local interface and it is working right now!! thanks!!
