IP PHONE REGISTRATION ISSUES
ahmedmaged9432
i have IP phone showing verify your network connection and won't work , when i enter static IP, it works ,in DHCP server i have  two IP scope one of them is complete the other have valid IP . is this require any thing in CUCM
Jaime Valencia
If the device is already configured in CUCM, or your CUCM is configured for auto-registration, that's it.
I'd make sure your DHCP has all the required parameters and that the device does get all the required network configuration to reach out to CUCM.
java
if this helps, please rate
this is new phone has'not been configured and dhcp server has all two scope but the phone won't take IP unless I assgin static IP for it
Nothing is required in CUCM for IP Address assignment.
1) Have you configured DHCP Relay so that DHCP Request are relayed to DHCP Server
2) Try creating a DHCP Server in the same subnet in switch or router.
3) Do a packet capture on PHone to see if we are receiving DHCP Response back. Just connect a PC with Wireshark Installed on Back of Phone.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
To add to what Haris suggested:
In the Status Messages on the phone, does it show DHCP Timeout or TFTP Timeout?
Maren
