IP Phone Remote Lock/Wipe
Karl Jacobsen
I've been reading about the new feature in CallManager 10.x where an administrator can lock or wipe an IP phone from the admin console. What model Cisco phones support this? I thought the 7942/7962 or 7945 would do this however I'm not seeing the option on the phone configuration page. What am I doing wrong?
ProductProtocolFeatureParameters
Cisco DX650SIPRemote Wipe
Cisco DX70SIPRemote Wipe
Cisco DX80SIPRemote Wipe
Best Regards,
Petko
EmilTaghiyev
If a phone does not support the functionality you have chosen, the transaction will fail for that phone. It will also fail if the functionality has already been requested for the phone
Procedures
Remotely Lock a Phone
Follow these steps to remotely lock a phone.
Procedure
    Step 1  Choose Device > Phone.
    The Find and List Phones window displays.
    Step 2  Enter search criteria and click Find to locate a specific phone.
    A list of phones that match the search criteria displays.
    Step 3  Choose the phone for which you want to perform a remote lock.
    The Phone Configuration window displays.
    Step 4  Click Lock. If the phone is not registered, a popup window displays to inform you that the phone will be locked the next time it is registered. Click Lock. A Device Lock/Wipe Status section appears, with information about the most recent request, whether it is pending, and the most recent acknowledgement.
    Remotely Wipe a Phone
    Follow these steps to remotely wipe a phone.
    Caution
    This operation cannot be undone. You should only perform this operation when you are sure you want to reset the phone to its factory settings.
    Procedure
      Step 3  Choose the phone for which you want to perform a remote wipe.
      Step 4  Click Wipe. If the phone is not registered, a popup window displays to inform you that the phone will be wiped the next time it is registered. Click Wipe. A Device Lock/Wipe Status section appears, with information about the most recent request, whether it is pending, and the most recent acknowledgment.
      [+5] to Emil.
      Hi Karl,
      please refer the link and follow similar guidelines for Remote Lock/Wipe a Phone feature.
      https://supportforums.cisco.com/document/12405736/determine-device-support-cisco-unified-communications-manager-assistant-ipma
      Hope this helps.
      regds,
      aman
      Best Regards,
      Petko
