02-17-2016 04:49 AM - edited 03-17-2019 05:55 AM
After selecting using directory button, phone displays (requesting) and never connects to directory. All other Cisco IP phones in system work correctly.
02-17-2016 05:20 AM
What are your other phone models?
It may be an issue with SSL or name resolution. Check in Enterprise Parameters - verify what the 'secured' directories URL is set to. You can delete the entry to force it to avoid SSL, or just check the entry is valid and if it's hostname rather than IP based, verify that the phones can resolve the name via DNS etc.
Aaron
04-08-2016 09:53 PM
In my case it is a Cisco 7940 model. Directory is not available when tried from phone. Only a single user facing issue. Don't think we need to check in Enterprise Parameter. Any help is really appreciated. Thanks!!
Biyas
12-15-2021 01:09 AM
@RONALD ANDERSON were u able to resolve this issue.
