07-14-2015 04:00 AM - edited 03-17-2019 03:38 AM
I want to enable web access for all IP Phones.
Only 3905 and 8831 IP Phones web access pages are working and some of the 8945.
9951, 7821, and 8761 all are not working.
I've checked every phone configuration, common phone profile, and enterprise phone configuration and the option is enabled.
Thanks in advance.
Solved! Go to Solution.
07-14-2015 04:10 AM
Have you reset the phones after making the change?
Aaron
07-14-2015 04:10 AM
Aaron
07-14-2015 04:15 AM
yes, I have reset all the phones after changing the configuration.
07-14-2015 06:23 AM
Try manually resetting one of the phones or disable enable web-access on one phone and see if that makes any difference.
Raman
08-24-2015 01:07 AM
Factory resetting the IP phones helped.
