09-23-2015 04:05 AM - edited 03-17-2019 04:22 AM
Is there a way to make jabber 11.0 on iPhone to work with CME and how?
Best regard
Mark
09-23-2015 04:22 AM
AFAIK Jabber 9.x is the highest version supported on CME 10.5.
On which version of CME you're?
09-23-2015 05:50 AM
HI Mark.
Unfortunately jabber for IPhone and Android are not yet supported on CUCME.
There was a Jabber Voice application for both platform that worked (and still works) with CUCME...
unfortunately it has been removed from app store and Play Store.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
Carlo
09-23-2015 06:45 AM
Hi Carlo,
After your comments, I also noticed the same. Do you mean Jabber on mobile platform is still supported with CME but not available on respective market for download?
09-23-2015 06:51 AM
Hi Vivek.
Correct...
Jabber Voice is still an option on CME 10.5 as voice register pool type but not downloadable from any store.
Cheers
Carlo
09-23-2015 11:45 PM
Hello guys,
the problem is also with ios 9 on iphones released few days ago, the jabber voice also stopped working, i was wonderinbif there is a way to make the jabber app to work with cucme or is there any 3rd party app we can use?
09-24-2015 01:21 AM
Hi Marc.
I just checked and you are right, with IOS9 it stopped working :(
Have you tried 3CX phone?
Let me know
Cheers
Carlo
10-02-2015 05:52 AM
Ok for the CME I tested a 3rd party softphone for IPhone named Join and for Android I used CSIPSimple and they are working fine.
For CUCM I tested the Jabber Phone only mode and its working.
Best regards
Mark Achkar
10-31-2015 05:47 AM
Marc,
I am passing for the same issue of the topic. I saw that you are using the Join SIP Client for Iphone and it works fine! I have tried the to use this software with CME but I didn´t have success. Please you share your configs of CME and the options used on Join SIP Client?
Best Regards,
Fábio Henrique
10-31-2015 06:42 AM
Hi Fabio.
Here what you need.
******CME SIDE*******
voice register global
source-address x.x.x.x port 5060 (x.x.x.x is your router interface ip address)
max-dn 10
max-pool 5
authenticate register
authenticate realm all
tftp-path flash:
file text
create profile
voice register dn 1
number 5220
allow watch
name Your displayed name
label line name
voice register pool 1
id mac 0000.1234.5678
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username cisco password cisco
no call-waiting
codec g711ulaw
*******Join Client Side*****
Username:5220
password:cisco
Auth. Unsername: cisco
Display Name:5220
Domain: Your router IP Address
Port: leave unchanged
Hope this helps
Carlo
10-31-2015 07:33 AM
Thanks Carlo,
Its now registering, but I am seeing some errors to make externals calls. But internals calls is the most important at this momment for me.
Thank you very much!
10-31-2015 07:43 AM
Glad That Helped :)
You can post the output of a debug ccsip message while calling outbound so I can help you further.
Please rate useful posts and mark as answered the one that solves your issue.
That will help others with same problem
Carlo
