IPhone Jabber 11.0 with CME
Marc El Achkar
Is there a way to make jabber 11.0 on iPhone to work with CME and how?
Best regard
Mark
11 Replies 11
Vivek Batra
AFAIK Jabber 9.x is the highest version supported on CME 10.5.
On which version of CME you're?
HI Mark.
Unfortunately jabber for IPhone and Android are not yet supported on CUCME.
There was a Jabber Voice application for both platform that worked (and still works) with CUCME...
unfortunately it has been removed from app store and Play Store.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
After your comments, I also noticed the same. Do you mean Jabber on mobile platform is still supported with CME but not available on respective market for download?
Hi Vivek.
Correct...
Jabber Voice is still an option on CME 10.5 as voice register pool type but not downloadable from any store.
Cheers
Carlo
Hello guys,
the problem is also with ios 9 on iphones released few days ago, the jabber voice also stopped working, i was wonderinbif there is a way to make the jabber app to work with cucme or is there any 3rd party app we can use?
Hi Marc.
I just checked and you are right, with IOS9 it stopped working :(
Have you tried 3CX phone?
Let me know
Cheers
Carlo
Ok for the CME I tested a 3rd party softphone for IPhone named Join and for Android I used CSIPSimple and they are working fine.
For CUCM I tested the Jabber Phone only mode and its working.
Best regards
Mark Achkar
Marc,
I am passing for the same issue of the topic. I saw that you are using the Join SIP Client for Iphone and it works fine! I have tried the to use this software with CME but I didn´t have success. Please you share your configs of CME and the options used on Join SIP Client?
Best Regards,
Fábio Henrique
Hi Fabio.
Here what you need.
******CME SIDE*******
voice register global
source-address x.x.x.x port 5060 (x.x.x.x is your router interface ip address)
max-dn 10
max-pool 5
authenticate register
authenticate realm all
tftp-path flash:
file text
create profile
voice register dn 1
number 5220
allow watch
name Your displayed name
label line name
voice register pool 1
id mac 0000.1234.5678
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username cisco password cisco
no call-waiting
codec g711ulaw
*******Join Client Side*****
Username:5220
password:cisco
Auth. Unsername: cisco
Display Name:5220
Domain: Your router IP Address
Port: leave unchanged
Hope this helps
Carlo
Thanks Carlo,
Its now registering, but I am seeing some errors to make externals calls. But internals calls is the most important at this momment for me.
Thank you very much!
Glad That Helped :)
You can post the output of a debug ccsip message while calling outbound so I can help you further.
Please rate useful posts and mark as answered the one that solves your issue.
That will help others with same problem
Carlo
