IR4331 VG202 FAX ERROR
Turalion
I use 4331 and vg202 to send and receive faxes. There is a problem. It is no problem to send to 1099 (VG202) via the internal number: 1098 (VG202) for example. However, if the content is sent to 9,86311099 via 9,86311098, the content will be incomplete, and communication errors are often reported.
The attachment is the configuration of 4331 and VG202
8 Replies 8
What protocol your ISP use, t.38 or pass through. if pass through add below  command under MGCP gateway configuration
mgcp modem passthrough voip codec g711alaw
Response Signature
Thank you for your answer.
My ISP told me that they are pass-through and suggested that we use T30
If isp use   pass through you need to use pass through.
Response Signature
I have used the pass through.
I have executed     mgcp modem passthrough voip codec g711alaw     in 4331. But the problem still exists.
Part of hte text is blurred.
is this the fax message you printed ? its  not clear what this screenshot is all about.
Response Signature
The entire page of this fax is a, and the content selected in red is an error caused by the fax.
I'm pretty sure that this kind of problem has nothing to do with printing, and the received content is problematic.
