07-02-2023 02:16 AM
Kindly advise if a 3rd party Hotline analog phone like VK-K-1900W-2 is compatible with Cucm via VG400
07-02-2023 05:19 AM
Hi @adeebtaqui
If we look at VG400 documentation it will be stated: "These FXS and FXO ports provide Dual-Tone Multifrequency (DTMF) detection"
Which means, it will be compatible with any analogic phone as any analogic phone out there must support DTMF. DTMF is the basic protocol for any analogic phones.
07-02-2023 05:34 AM
Any analog phone should be supported. If I’m looking at the specs for the VK-K-1900W-2 I can’t see anything out of the ordinary, so I’m going to say that it should be supported.
07-02-2023 09:00 PM
You can connect this as analogue and it should work with the CUCM Via VG400 and can be configured as hotline phone.
