10-02-2013 10:39 AM - edited 03-16-2019 07:39 PM
As it stands now, when we pass through caller id, it appears as (+16021234567). The problem is that when the call is active, the box displaying the caller id and the call timer shows (+160212345...
This has become a problem for some of our end users. Does anyone know if we can edit the caller id display to be smaller so that the full number shows?
Thanks...Jason
10-02-2013 11:36 AM
No way to change the font or size that's displayed on the phones.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-02-2013 11:41 AM
Thanks, I figured as much.
10-02-2013 01:14 PM
Different firmware versions have changed this text size a bit. You could try a few different firmware versions to see if any of them work.
10-02-2013 02:21 PM
It looks like the last 2 digits are being hidden. You could change the inbound call id to strip the leading +1.
