ISDN layer 2 flapping
Steellllllllll0
Hi All,
I have a problem with an isdn circuit layer 2 and have been through other postings but none have helped so far.
*Oct 2 12:06:49.391: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state t
o down (AIS detected)
*Oct 2 12:06:49.395: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/1/0:15, TEI
0 changed to down
*Oct 2 12:06:51.391: %LINK-3-UPDOWN: Interface Serial0/1/0:15, changed state to
down
*Oct 2 12:07:15.391: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state t
o up
*Oct 2 12:07:15.411: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/1/0:15, TEI 0
changed to up
*Oct 2 12:07:17.391: %LINK-3-UPDOWN: Interface Serial0/1/0:15, changed state to
up
*Oct 2 12:07:36.391: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state t
o down (RAI detected)
*Oct 2 12:07:36.395: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/1/0:15, TEI
0 changed to down
*Oct 2 12:07:38.391: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state t
o up
*Oct 2 12:07:38.419: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/1/0:15, TEI 0
changed to up
*Oct 2 12:07:46.459: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/1/0:15, TEI
0 changed to downC
Any ideas ??
6 Replies 6
slongewa
I'm from the US and don't get to see E1's very often, but the last time I saw behavior like this, I had to have the Telco change the port out that they were using on their switch and it resolved the problem. Have you tried anything with the Telco yet?
HTH,
Steve
amit.gaur
I have changed BRI card but still showing below logs
Aug 22 09:10:23.256: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 89 changed to up
Aug 22 09:10:32.116: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 80 changed to down
Aug 22 09:10:32.116: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 89 changed to down
Aug 22 09:11:10.321: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 96 changed to up
Aug 22 09:11:10.465: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 105 changed to up
Aug 22 09:12:07.123: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 96 changed to down
Aug 22 09:12:07.123: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 105 changed to down
Aug 22 09:12:37.680: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 112 changed to up
Aug 22 09:12:37.816: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 65 changed to up
Kindly check the PIN-OUT to be used. Make sure the cable connected is according to the recommended PIN-OUT. Also if there is any working cable, you can try that as well.
Check the framing and CRC set from the ISP and configure it acordingly on your side. Try to bounce the framing on the controller.
Provider can also check on their end too.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Dennis Mink
dont waste any time, book it out to the telco. have them test mdf/idf
please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
Thanks same has been shared with telco
Keep this thread posted
Abhay
Abhay Singh Reyal
