ISDN Se0/0/0:15 **ERROR**: L3_Ge, )
ikabuthu1
I am using Cisco 2921 CME.
I cannot make international calls and I cannot receive any call through the gateway. Kindly help.
Below are the debug messages . I will be happy to provide more info.
*Sep  1 13:46:32.691: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x808A
        Cause i = 0x829C - Invalid number format (incomplete number)
*Sep  1 13:46:32.691: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x008A
*Sep  1 13:46:32.863: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808A
*Sep  1 13:49:21.119: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0360
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Calling Party Number i = 0x2183, '716533575'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '000'
                Plan:ISDN, Type:Subscriber(local)
*Sep  1 13:49:21.119: ISDN Se0/0/0:15 **ERROR**: L3_Ge
YALI2921#tUser_NLCB: DUPLICATE SETUP, message ignored.
The configs are;
YALI2921#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
YALI2921#sh run | sec dial-peer
dial-peer voice 10 pots
 description SAFARICOM
 translation-profile incoming INCOMING
 service mgcpapp
 destination-pattern 9..........
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
 forward-digits 10
dial-peer voice 11 pots
 description INTERNATIONAL_CALLS
 preference 1
 destination-pattern 9............
 port 0/0/0:15
 forward-digits 15
YALI2921#
YALI2921#sh run | sec translation
voice translation-rule 1
 rule 1 /\(...\)/ /1\1/
voice translation-rule 2
 rule 1 /1.../ /0719030000/
voice translation-profile INCOMING
 translate called 1
voice translation-profile OUTGOING
 translate calling 2
 translation-profile outgoing OUTGOING
Nadeem Ahmed
The number pattern for called number is incorrect. Generally for any international call Telco expect 011-then 10 digit number . Can you please post the show run and make another test call collecting below debug. have you also applied translation rule on voice-port ?
Debug isdn q931
debug voice ccapi inout
Br, Nadeem Please rate all useful post.
avinsrid89
Why is the called number 000? :O
Also, please paste complete 'debug isdn q931' .
~Avinash
Hi team. Here are the debugs and sh run.
YALI2921#debug isdn q931
debug isdn q931 is              ON.
YALI2921#
*Sep  2 05:35:32.583: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00A4
        Cause i = 0x8090 - Normal call clearing
*Sep  2 05:35:32.731: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80A4
*Sep  2 05:35:32.731: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00A4
YALI2921#
*Sep  2 05:36:22.047: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0B4D
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98389
                Exclusive, Channel 9
*Sep  2 05:36:22.047: ISDN Se0/0/0:15 Q931: Received S
YALI2921#ETUP  callref = 0x8B4D callID = 0x0027 switch = primary-net5 interface = User
YALI2921#
*Sep  2 05:36:26.027: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0B4D
        Sending Complete
                Standard = CCITT
*Sep  2 05:36:26.027: ISDN Se0/0/0:15 **ERROR**: L3_Ge
YALI2921#OBclusive, Channel 31
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '0719030000'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '0726866045'
*Sep  2 05:56:32.911: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80AD
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
*Sep  2 05:56:33.251: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80AD
        Progress Ind i = 0x8288 - In-band info or appropri
YALI2921#OBate now available
YALI2921#OB
*Sep  2 05:56:35.891: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80AD
        Progress Ind i = 0x8288 - In-band info or appropriate now available
YALI2921#OB
*Sep  2 05:56:43.731: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x80AD
        Progress Ind i = 0x8284 - Call has returned to the ISDN
        Date/Time i = 0x0F0902083922
                Date (dd-mm-yr)   = 15-09-02
                Time (hr:mnt:sec) = 08:57:34
*Sep  2 05:56:43.731: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x00AD
YALI2921#OB
*Sep  2 05:56:59.899: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80AD
*Sep  2 05:56:59.903: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00AD
*Sep  2 05:57:00.051: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80AD
YALI2921#sh
*Sep  2 05:38:32.523: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep  2 05:38:32.523: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00A6 callID = 0x8027 switch = primary-net5 interface = User
*Sep  2 05:38:32.523: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A6
                Standard = CCITT
                Ex
YALI2921#clusive, Channel 31
        Called Party Number i = 0x80, '00090002564177'
                Plan:Unknown, Type:Unknown
*Sep  2 05:38:32.703: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80A6
*Sep  2 05:38:33.843: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80A6
        Cause i = 0x8281 - Unallocated/unassigned
YALI2921#number
*Sep  2 05:38:33.843: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00A6
*Sep  2 05:38:34.003: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A6
*Sep  2 05:38:34.007: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep  2 05:38:34.011: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00A7 callID = 0x8028 switch = primary-net5 interface = User
YALI2921#5:38:34.011: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A7
                Standard = CCITT
        Called Party Number i = 0x80, '0002564177'
*Sep  2 05:38:34.175: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80A7
        Channe
YALI2921#l ID i = 0xA9839F
YALI2921#
*Sep  2 05:38:49.983: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80A7
*Sep  2 05:38:49.983: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00A7
*Sep  2 05:38:50.115: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A7
*Sep  2 05:38:50.119: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep  2 05:38:50.119: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0
YALI2921#x00A8 callID = 0x8029 switch = primary-net5 interface = User
*Sep  2 05:38:50.119: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A8
                Standard = CCITT
YALI2921#x81
*Sep  2 05:38:50.283: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80A8
YALI2921#
*Sep  2 05:38:58.367: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00A8
*Sep  2 05:38:58.543: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80A8
*Sep  2 05:38:58.543: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00A8
YALI2921#
YALI2921#
*Sep  2 06:06:10.811: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00AF
*Sep  2 06:06:10.975: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80AF
*Sep  2 06:06:10.975: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00AF
YALI2921#
*Sep  2 06:06:18.891: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep  2 06:06:18.891: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00B0 callID = 0x8031 switch = primary-net5 interface = User
*Sep  2 06:06:18.891: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00B0
                Standard = CCITT
                Ex
*Sep  2 06:06:19.087: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80B0
YALI2921#
*Sep  2 06:06:20.163: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80B0
        Cause i = 0x8281 - Unallocated/unassigned number
*Sep  2 06:06:20.163: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00B0
*Sep  2 06:06:20.335: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80B0
*Sep  2 06:06:20.343: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep  2 06:06:20.343: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00B1 callID
YALI2921# = 0x8032 switch = primary-net5 interface = User
*Sep  2 06:06:20.343: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00B1
                Standard = CCITT
YALI2921#4177'
*Sep  2 06:06:20.499: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80B1
YALI2921#
*Sep  2 06:06:36.255: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80B1
*Sep  2 06:06:36.255: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00B1
*Sep  2 06:06:36.415: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80B1
YALI2921#
YALI2921#sh run b
Building configuration...
Current configuration : 11948 bytes
! Last configuration change at 17:59:10 Nairobi Tue Sep 1 2015
version 15.5
hostname YALI2921
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/2
logging buffered 51200 warnings
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone Nairobi 3 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip dhcp excluded-address 10.1.2.1 10.1.2.10
ip dhcp excluded-address 10.1.3.1 10.1.3.10
ip dhcp excluded-address 10.1.5.1 10.1.5.10
ip dhcp excluded-address 10.1.1.1 10.1.1.100
ip dhcp pool ccp-pool
 import all
 network 10.10.10.0 255.255.255.128
 default-router 10.10.10.1
 lease 0 2
ip dhcp pool VLAN20
 network 10.1.2.0 255.255.255.0
 default-router 10.1.2.1
 dns-server 10.1.1.100
ip dhcp pool VLAN30
 network 10.1.3.0 255.255.255.0
 default-router 10.1.3.1
ip dhcp pool VOICE
 network 10.1.5.0 255.255.255.0
 default-router 10.1.5.1
 option 150 ip 10.1.5.1
ip dhcp pool VLAN10
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
no ip domain lookup
ip domain name rtp.cisco.com
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
crypto pki trustpoint TP-self-signed-3060233408
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3060233408
 revocation-check none
 rsakeypair TP-self-signed-3060233408
crypto pki certificate chain TP-self-signed-3060233408
 certificate self-signed 01
voice-card 0
voice service voip
 ip address trusted list
  ipv4 10.1.0.0 255.255.255.0
  ipv4 10.2.0.0 255.255.255.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 1200 min 300
voice register pool-type  8841
 xml-config maxNumCalls 3
 xml-config busyTrigger 3
 phoneload-support
 telnet-support
 transport tcp
 num-lines 10
 addons 3
 description Cisco 8841 Phone
 reference-pooltype 6941
voice register global
 mode  cme
 source-address 10.1.5.1 port 5060
 max-dn 50
 max-pool 30
 load 8841 sip88xx.10-2-2-16.loads
 authenticate register
 timezone 21
 time-format 24
 date-format D/M/Y
 voicemail 88888888
 service https
 tftp-path flash:
 file text
 create profile sync 0006801043312858
 video
voice register dn  5
 number 1005
 name Admin Officer
 label Admin Officer
voice register dn  6
 number 1006
 name Mark Mccord
 label Mark Mccord
voice register dn  7
 number 1004
 name IT Manager
 label IT Manager
voice register dn  8
 number 1007
 name Maggie Kamau
 label Maggie Kamau
voice register dn  9
 number 1003
 name SEM Room 3
 label SEM Room 3
voice register dn  10
 number 1000
 name  RECEPTION
 label  RECEPTION
voice register pool  5
 busy-trigger-per-button 1
 id mac BC16.F517.1BB6
 type 8841
 number 1 dn 5
 presence call-list
 dtmf-relay rtp-nte
 username admin password 1234
 codec g711ulaw
voice register pool  6
 id mac BC16.F5FA.683C
 type 8841
 number 1 dn 6
 presence call-list
 dtmf-relay rtp-nte
 username mark password 1234
 codec g711ulaw
voice register pool  7
 id mac BC16.F5FB.56E6
 type 8841
 number 1 dn 7
 presence call-list
 dtmf-relay rtp-nte
 username itmanager password 1234
 codec g711ulaw
voice register pool  8
 id mac BC16.F517.3A0A
 type 8841
 number 1 dn 8
 presence call-list
 dtmf-relay rtp-nte
 username maggie password 1234
 codec g711ulaw
voice register pool  9
 id mac BC16.F517.1A8B
 type 8841
 number 1 dn 9
 presence call-list
 dtmf-relay rtp-nte
 username semroom3 password 1234
 codec g711ulaw
voice register pool  10
 id mac BC16.F517.1AEF
 type 8841
 number 1 dn 10
 presence call-list
 dtmf-relay rtp-nte
 username YALI password 1234
 dnd
 codec g711ulaw
 translate called 1
 translate calling 2
license udi pid CISCO2921/K9 sn FCZ19256063
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31
 description Safaricom 0719030000
controller E1 0/0/1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 description LINK_TO_VLAN-10
 encapsulation dot1Q 10
 ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/0.20
 description LINK_TO_VLAN-20
 encapsulation dot1Q 20
 ip address 10.1.2.1 255.255.255.0
interface GigabitEthernet0/0.30
 description LINK_TO_VLAN-30
 encapsulation dot1Q 30
 ip address 10.1.3.1 255.255.255.0
interface GigabitEthernet0/0.40
 description LINK_TO_VLAN-40
 encapsulation dot1Q 40
 ip address 10.1.4.1 255.255.255.0
interface GigabitEthernet0/0.50
 description LINK_TO_VLAN-50
 encapsulation dot1Q 50
 ip address 10.1.5.1 255.255.255.0
interface GigabitEthernet0/1
 description LINK_TO_KU_NETWORK-PRIMARY
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description LINK_TO_KU_NETWORK-SECONDARY
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn map address ^000* plan unknown type unknown
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.1.0.0 255.255.0.0 GigabitEthernet0/1
tftp-server flash:fbi88xx.BE-01-009.sbn
tftp-server flash:kern88xx.10-2-2-16.sbn
tftp-server flash:rootfs88xx.10-2-2-16.sbn
tftp-server flash:sb288xx.BE-01-018.sbn
tftp-server flash:sip88xx.10-2-2-16.loads alias sip88xx.10-2-2-16
tftp-server flash:vc488xx.10-2-2-16.sbn
tftp-server flash:fbi88xx.BE-01-009.sbn alias fbi88xx.BE-01-009.sbn
tftp-server flash:kern88xx.10-2-2-16.sbn alias kern88xx.10-2-2-16.sbn
tftp-server flash:rootfs88xx.10-2-2-16.sbn alias rootfs88xx.10-2-2-16.sbn
tftp-server flash:sb288xx.BE-01-018.sbn alias sb288xx.BE-01-018.sbn
tftp-server flash:vc488xx.10-2-2-16.sbn alias vc488xx.10-2-2-16.sbn
access-list 23 permit 10.10.10.0 0.0.0.127
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
 connection plar opx immediate 1000
voice-port 0/1/1
 supervisory disconnect dualtone mid-call
 cptone KE
 timeouts interdigit 3
 timeouts call-disconnect 2
 caller-id enable
mgcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 service mgcpapp
 direct-inward-dial
 port 0/0/0:15
 forward-digits 10
sip-ua
gatekeeper
 shutdown
telephony-service
 max-ephones 25
 max-dn 25
 ip source-address 10.1.5.1 port 2000
 auto assign 100 to 200
 time-zone 32
 max-conferences 8 gain -6
 transfer-system full-consult
ephone-dn  1
 number 1010
 label Mark Mccord
 description 1010
 name Mark Mccord
ephone-dn  2
 number 1001
 label SEM Room 1
 description 1001
 name SEM Room 1
ephone-dn  5  dual-line
 number 1000
 label YALI Reception
 description 1000
 name YALI Reception
ephone-dn  6  dual-line
 number 1 secondary 1
 label Isaac Kabuthu
 description 1111
 name Isaac Kabuthu
ephone-dn  7
 number 1011
 label Agnes Mittau
 description 1000
 name Agnes Mittau
ephone  1
 mac-address FCFB.FB10.A5BF
 type 7940
 button  1:1
ephone  2
 mac-address 3037.A616.9D96
 type 7940
 button  1:2
YALI2921#
I dont know why the called number is "000"
Could this be  a course ?
YALI2921#sh run int s0/0/0:15
Current configuration : 190 bytes
 no ip address
 encapsulation hdlc
 no cdp enable
end
