09-01-2015 06:55 AM - edited 03-17-2019 04:10 AM
I am using Cisco 2921 CME.
I cannot make international calls and I cannot receive any call through the gateway. Kindly help.
Below are the debug messages . I will be happy to provide more info.
*Sep 1 13:46:32.691: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x808A
Cause i = 0x829C - Invalid number format (incomplete number)
*Sep 1 13:46:32.691: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x008A
*Sep 1 13:46:32.863: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x808A
*Sep 1 13:49:21.119: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0360
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
Exclusive, Channel 5
Calling Party Number i = 0x2183, '716533575'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '000'
Plan:ISDN, Type:Subscriber(local)
*Sep 1 13:49:21.119: ISDN Se0/0/0:15 **ERROR**: L3_Ge
YALI2921#tUser_NLCB: DUPLICATE SETUP, message ignored.
The configs are;
YALI2921#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
YALI2921#sh run | sec dial-peer
dial-peer voice 10 pots
description SAFARICOM
translation-profile incoming INCOMING
service mgcpapp
destination-pattern 9..........
incoming called-number .
direct-inward-dial
port 0/0/0:15
forward-digits 10
dial-peer voice 11 pots
description INTERNATIONAL_CALLS
preference 1
destination-pattern 9............
port 0/0/0:15
forward-digits 15
YALI2921#
YALI2921#sh run | sec translation
voice translation-rule 1
rule 1 /\(...\)/ /1\1/
voice translation-rule 2
rule 1 /1.../ /0719030000/
voice translation-profile INCOMING
translate called 1
voice translation-profile OUTGOING
translate calling 2
translation-profile outgoing OUTGOING
09-01-2015 10:47 AM
The number pattern for called number is incorrect. Generally for any international call Telco expect 011-then 10 digit number . Can you please post the show run and make another test call collecting below debug. have you also applied translation rule on voice-port ?
Debug isdn q931
debug voice ccapi inout
09-01-2015 01:52 PM
Why is the called number 000? :O
Also, please paste complete 'debug isdn q931' .
~Avinash
09-01-2015 11:38 PM
Hi team. Here are the debugs and sh run.
YALI2921#debug isdn q931
debug isdn q931 is ON.
YALI2921#
*Sep 2 05:35:32.583: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00A4
Cause i = 0x8090 - Normal call clearing
*Sep 2 05:35:32.731: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80A4
*Sep 2 05:35:32.731: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00A4
YALI2921#
*Sep 2 05:36:22.047: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0B4D
Sending Complete
Standard = CCITT
Channel ID i = 0xA98389
Exclusive, Channel 9
*Sep 2 05:36:22.047: ISDN Se0/0/0:15 Q931: Received S
YALI2921#ETUP callref = 0x8B4D callID = 0x0027 switch = primary-net5 interface = User
YALI2921#
*Sep 2 05:36:26.027: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0B4D
Sending Complete
Standard = CCITT
*Sep 2 05:36:26.027: ISDN Se0/0/0:15 **ERROR**: L3_Ge
YALI2921#OBclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '0719030000'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0726866045'
*Sep 2 05:56:32.911: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80AD
Channel ID i = 0xA9839F
Exclusive, Channel 31
*Sep 2 05:56:33.251: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80AD
Progress Ind i = 0x8288 - In-band info or appropri
YALI2921#OBate now available
YALI2921#OB
*Sep 2 05:56:35.891: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80AD
Progress Ind i = 0x8288 - In-band info or appropriate now available
YALI2921#OB
*Sep 2 05:56:43.731: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x80AD
Progress Ind i = 0x8284 - Call has returned to the ISDN
Date/Time i = 0x0F0902083922
Date (dd-mm-yr) = 15-09-02
Time (hr:mnt:sec) = 08:57:34
*Sep 2 05:56:43.731: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x00AD
YALI2921#OB
*Sep 2 05:56:59.899: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80AD
*Sep 2 05:56:59.903: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00AD
*Sep 2 05:57:00.051: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80AD
YALI2921#sh
*Sep 2 05:38:32.523: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep 2 05:38:32.523: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00A6 callID = 0x8027 switch = primary-net5 interface = User
*Sep 2 05:38:32.523: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A6
Standard = CCITT
Ex
YALI2921#clusive, Channel 31
Called Party Number i = 0x80, '00090002564177'
Plan:Unknown, Type:Unknown
*Sep 2 05:38:32.703: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80A6
*Sep 2 05:38:33.843: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80A6
Cause i = 0x8281 - Unallocated/unassigned
YALI2921#number
*Sep 2 05:38:33.843: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00A6
*Sep 2 05:38:34.003: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A6
*Sep 2 05:38:34.007: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep 2 05:38:34.011: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00A7 callID = 0x8028 switch = primary-net5 interface = User
YALI2921#5:38:34.011: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A7
Standard = CCITT
Called Party Number i = 0x80, '0002564177'
*Sep 2 05:38:34.175: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80A7
Channe
YALI2921#l ID i = 0xA9839F
YALI2921#
*Sep 2 05:38:49.983: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80A7
*Sep 2 05:38:49.983: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00A7
*Sep 2 05:38:50.115: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A7
*Sep 2 05:38:50.119: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep 2 05:38:50.119: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0
YALI2921#x00A8 callID = 0x8029 switch = primary-net5 interface = User
*Sep 2 05:38:50.119: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A8
Standard = CCITT
YALI2921#x81
*Sep 2 05:38:50.283: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80A8
YALI2921#
*Sep 2 05:38:58.367: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00A8
*Sep 2 05:38:58.543: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80A8
*Sep 2 05:38:58.543: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00A8
YALI2921#
YALI2921#
*Sep 2 06:06:10.811: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00AF
*Sep 2 06:06:10.975: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80AF
*Sep 2 06:06:10.975: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00AF
YALI2921#
*Sep 2 06:06:18.891: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep 2 06:06:18.891: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00B0 callID = 0x8031 switch = primary-net5 interface = User
*Sep 2 06:06:18.891: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00B0
Standard = CCITT
Ex
*Sep 2 06:06:19.087: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80B0
YALI2921#
*Sep 2 06:06:20.163: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80B0
Cause i = 0x8281 - Unallocated/unassigned number
*Sep 2 06:06:20.163: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00B0
*Sep 2 06:06:20.335: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80B0
*Sep 2 06:06:20.343: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0719030000
*Sep 2 06:06:20.343: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00B1 callID
YALI2921# = 0x8032 switch = primary-net5 interface = User
*Sep 2 06:06:20.343: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00B1
Standard = CCITT
YALI2921#4177'
*Sep 2 06:06:20.499: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80B1
YALI2921#
*Sep 2 06:06:36.255: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80B1
*Sep 2 06:06:36.255: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00B1
*Sep 2 06:06:36.415: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80B1
YALI2921#
YALI2921#sh run b
Building configuration...
Current configuration : 11948 bytes
! Last configuration change at 17:59:10 Nairobi Tue Sep 1 2015
version 15.5
hostname YALI2921
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/2
logging buffered 51200 warnings
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone Nairobi 3 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip dhcp excluded-address 10.1.2.1 10.1.2.10
ip dhcp excluded-address 10.1.3.1 10.1.3.10
ip dhcp excluded-address 10.1.5.1 10.1.5.10
ip dhcp excluded-address 10.1.1.1 10.1.1.100
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
ip dhcp pool VLAN20
network 10.1.2.0 255.255.255.0
default-router 10.1.2.1
dns-server 10.1.1.100
ip dhcp pool VLAN30
network 10.1.3.0 255.255.255.0
default-router 10.1.3.1
ip dhcp pool VOICE
network 10.1.5.0 255.255.255.0
default-router 10.1.5.1
option 150 ip 10.1.5.1
ip dhcp pool VLAN10
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
no ip domain lookup
ip domain name rtp.cisco.com
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
crypto pki trustpoint TP-self-signed-3060233408
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3060233408
revocation-check none
rsakeypair TP-self-signed-3060233408
crypto pki certificate chain TP-self-signed-3060233408
certificate self-signed 01
voice-card 0
voice service voip
ip address trusted list
ipv4 10.1.0.0 255.255.255.0
ipv4 10.2.0.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 1200 min 300
voice register pool-type 8841
xml-config maxNumCalls 3
xml-config busyTrigger 3
phoneload-support
telnet-support
transport tcp
num-lines 10
addons 3
description Cisco 8841 Phone
reference-pooltype 6941
voice register global
mode cme
source-address 10.1.5.1 port 5060
max-dn 50
max-pool 30
load 8841 sip88xx.10-2-2-16.loads
authenticate register
timezone 21
time-format 24
date-format D/M/Y
voicemail 88888888
service https
tftp-path flash:
file text
create profile sync 0006801043312858
video
voice register dn 5
number 1005
name Admin Officer
label Admin Officer
voice register dn 6
number 1006
name Mark Mccord
label Mark Mccord
voice register dn 7
number 1004
name IT Manager
label IT Manager
voice register dn 8
number 1007
name Maggie Kamau
label Maggie Kamau
voice register dn 9
number 1003
name SEM Room 3
label SEM Room 3
voice register dn 10
number 1000
name RECEPTION
label RECEPTION
voice register pool 5
busy-trigger-per-button 1
id mac BC16.F517.1BB6
type 8841
number 1 dn 5
presence call-list
dtmf-relay rtp-nte
username admin password 1234
codec g711ulaw
voice register pool 6
id mac BC16.F5FA.683C
type 8841
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
username mark password 1234
codec g711ulaw
voice register pool 7
id mac BC16.F5FB.56E6
type 8841
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
username itmanager password 1234
codec g711ulaw
voice register pool 8
id mac BC16.F517.3A0A
type 8841
number 1 dn 8
presence call-list
dtmf-relay rtp-nte
username maggie password 1234
codec g711ulaw
voice register pool 9
id mac BC16.F517.1A8B
type 8841
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
username semroom3 password 1234
codec g711ulaw
voice register pool 10
id mac BC16.F517.1AEF
type 8841
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
username YALI password 1234
dnd
codec g711ulaw
translate called 1
translate calling 2
license udi pid CISCO2921/K9 sn FCZ19256063
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
description Safaricom 0719030000
controller E1 0/0/1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description LINK_TO_VLAN-10
encapsulation dot1Q 10
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/0.20
description LINK_TO_VLAN-20
encapsulation dot1Q 20
ip address 10.1.2.1 255.255.255.0
interface GigabitEthernet0/0.30
description LINK_TO_VLAN-30
encapsulation dot1Q 30
ip address 10.1.3.1 255.255.255.0
interface GigabitEthernet0/0.40
description LINK_TO_VLAN-40
encapsulation dot1Q 40
ip address 10.1.4.1 255.255.255.0
interface GigabitEthernet0/0.50
description LINK_TO_VLAN-50
encapsulation dot1Q 50
ip address 10.1.5.1 255.255.255.0
interface GigabitEthernet0/1
description LINK_TO_KU_NETWORK-PRIMARY
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description LINK_TO_KU_NETWORK-SECONDARY
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address ^000* plan unknown type unknown
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.1.0.0 255.255.0.0 GigabitEthernet0/1
tftp-server flash:fbi88xx.BE-01-009.sbn
tftp-server flash:kern88xx.10-2-2-16.sbn
tftp-server flash:rootfs88xx.10-2-2-16.sbn
tftp-server flash:sb288xx.BE-01-018.sbn
tftp-server flash:sip88xx.10-2-2-16.loads alias sip88xx.10-2-2-16
tftp-server flash:vc488xx.10-2-2-16.sbn
tftp-server flash:fbi88xx.BE-01-009.sbn alias fbi88xx.BE-01-009.sbn
tftp-server flash:kern88xx.10-2-2-16.sbn alias kern88xx.10-2-2-16.sbn
tftp-server flash:rootfs88xx.10-2-2-16.sbn alias rootfs88xx.10-2-2-16.sbn
tftp-server flash:sb288xx.BE-01-018.sbn alias sb288xx.BE-01-018.sbn
tftp-server flash:vc488xx.10-2-2-16.sbn alias vc488xx.10-2-2-16.sbn
access-list 23 permit 10.10.10.0 0.0.0.127
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
connection plar opx immediate 1000
voice-port 0/1/1
supervisory disconnect dualtone mid-call
cptone KE
timeouts interdigit 3
timeouts call-disconnect 2
caller-id enable
mgcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
service mgcpapp
direct-inward-dial
port 0/0/0:15
forward-digits 10
sip-ua
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 25
ip source-address 10.1.5.1 port 2000
auto assign 100 to 200
time-zone 32
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn 1
number 1010
label Mark Mccord
description 1010
name Mark Mccord
ephone-dn 2
number 1001
label SEM Room 1
description 1001
name SEM Room 1
ephone-dn 5 dual-line
number 1000
label YALI Reception
description 1000
name YALI Reception
ephone-dn 6 dual-line
number 1 secondary 1
label Isaac Kabuthu
description 1111
name Isaac Kabuthu
ephone-dn 7
number 1011
label Agnes Mittau
description 1000
name Agnes Mittau
ephone 1
mac-address FCFB.FB10.A5BF
type 7940
button 1:1
ephone 2
mac-address 3037.A616.9D96
type 7940
button 1:2
YALI2921#
I dont know why the called number is "000"
09-02-2015 01:13 AM
Could this be a course ?
YALI2921#sh run int s0/0/0:15
Current configuration : 190 bytes
no ip address
encapsulation hdlc
no cdp enable
end
