ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
arnela.jokhoo
Guys,
I am having this issue and i just need to verify, or justify to the telco that my configs are correct and the issue is maybe a loop on their switching
i've tried changing isdn switch-type and related configs to primary-net5 as this is E1, but no changes.
the debugs just show bad frames, i have been following this post as well. Any assistance i can get i will appreciate thanks
https://supportforums.cisco.com/thread/2038702
Config
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn sending-complete
no cdp enable
Router#sh controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  Description: DIGICEL
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (883 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 60 15 minute intervals):
     26 Line Code Violations, 1 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 22 Line Err Secs, 0 Degraded Mins,
     22 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Router#sh isdn stat
Global ISDN Switchtype = primary-qsig
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
        TEI = 255, Ces = 255, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 239
    Total Allocated ISDN CCBs = 0
debug isdn q921 is              ON.
*Dec 24 15:36:13.260: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 24 15:36:13.260: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=127
*Dec 24 15:36:13.260: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x00FF7F)
*Dec 24 15:36:14.260: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=127
Router#
*Dec 24 15:36:14.260: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x00FF7F)
*Dec 24 15:36:15.260: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=127
Router#
*Dec 24 15:36:15.260: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x00FF7F)
*Dec 24 15:36:16.260: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=127
Router#
*Dec 24 15:36:16.260: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x00FF7F)
debug isdn q931 is              ON.
Router##BAD FRAME()
Router#BAD FRAME()
Router#BAD FRAME()
Router#BAD FRAME()
*Dec 24 15:37:29.259: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Ask telco to revise their config, because it seems like they're set user-side.
5 Replies 5
acampbell
Hi Arnela,
I think you have 2 issues.
Can you try chanmging your config a little
Conf t
shut
isdn switch-type primary-net5
no shut
controller E1 0/0/0
shut
framing CRC4
no shut
Festive Greetings to You & Yours
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
thanks for your quick response, think maybe i confused everyone...
The service provider is using isdn switch-type primary-qsig its why i have qsig in the configs.
what i was trying to say is that i also reconfigured with the configs you posted as well but it didnt work either.
however if you think of anything else i would appreciate..thanks a mil..
thanks for your greeting,
Hope you also have a wonderful holiday Season! All best wishes to you and yours
Hi Paolo,
I was thinking the same, but they keep telling me their configs are good.. I will ask again.
thanks alot!
will let you know
thanks everyone, the problem was definitely on the service provider's end once they resolved it came up fine
