11-30-2010 06:57 AM - edited 03-16-2019 02:11 AM
Sanity check please. Our Paris Office has just moved within the city and I'm having real trouble with France Telecom.
I am running 2621XM with an NM-HDV2 with a VWIC-1E1 as an h.323 gateway to CCM7.
The E1 circuit is up and clean. Outbound calls work perfectly. A debug isdn q931 shows all the appropriate activity.
However, when dialling in from outside there is no Q.931 activity at all. France Telecom swear blind that they have ported the DDI range across.
My question is; is it possible for there to be an error at my end that would result on a clear E1 circuit but no q.931 on inbound only.
I will post config if required.
Thanks advance.
Rich
11-30-2010 10:25 AM
No, there is no possible error on your side.
When telco swears blind about something, invite them on premises with their own test equipment - then sit and enjoy the show.
11-30-2010 11:38 AM
Thanks I'll get them on-site.
11-30-2010 01:59 PM
You are welcome, thanks for the nice rating and good luck!
07-23-2013 02:58 AM
Hi Rich
I'm planning for a CUCM site in France and need some configuration Help
we have 3 sites:
SiteA : 5 T0 lines
SiteB : 3 T0 lines
SiteC: 1 T2
i believe T0 is ISDN BRI and T2 is PRI, can you please share some working configuration for these 2 ISDN types
appreciate your help
Shameer
07-23-2013 08:48 AM
This is an ISDN30 config...
Use show controller e1 to see if the E1 controller has alarm, if so you may have to change the framing to no-crc4
card type e1 1 1
logging buffered 4096 debugging
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
no network-clock-participate slot 1
no network-clock-participate wic 0
aaa new-model
aaa authentication login default local group radius
aaa authorization exec default local group radius
aaa authorization network default local group radius
aaa session-id common
ip subnet-zero
ip cef
ip dhcp relay information option
no ftp-server write-enable
isdn switch-type primary-net5
voice-card 1
dsp services dspfarm
voice call convert-discpi-to-prog
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 3
rule 1 reject /078[bad person phone number]/
voice translation-profile call_block
translate calling 3
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
translation-rule 1
Rule 1 ^. 90
translation-rule 2
Rule 1 ^3000 3472
Rule 2 ^2610 3471
Rule 3 ^9000 3471
interface FastEthernet0/0
ip address [ip of this interface] 255.255.255.0
speed auto
full-duplex
h323-gateway voip bind srcaddr [ip of this interface]
interface FastEthernet0/1
no ip address
shutdown
speed 100
full-duplex
interface Serial1/0:15
description Trunk to ISDX
no ip address
isdn overlap-receiving
isdn incoming-voice voice
isdn map address . plan isdn type unknown
no cdp enable
interface Serial1/1:15
description ISDN Trunk to PSTN
no ip address
no cdp enable
ip classless
ip route blah blah blah
no ip http server
ip radius source-interface FastEthernet0/0
snmp-server community xxxxxxx RW
snmp-server enable traps tty
radius-server host [ip of radius] auth-port 1645 acct-port 1646
radius-server key 7 xxxxxxxxxxxx
control-plane
voice-port 1/0:15
translate calling 10
translate called 2
input gain 1
output attenuation -3
cptone GB
bearer-cap Speech
voice-port 1/1:15
translate called 2
cptone GB
bearer-cap Speech
dial-peer voice 101 voip
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
destination-pattern ....
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:[ip address of your CUCM]
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 102 voip
preference 2
translate-outgoing calling 3
session target ipv4:[ip address of your 2nd CUCM]
fax rate disable
no vad
dial-peer voice 9 pots
tone ringback alert-no-PI
destination-pattern 9.T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
fax rate disable
direct-inward-dial
port 1/0:15
dial-peer voice 8 pots
fax rate disable
direct-inward-dial
port 1/1:15
end
07-23-2013 08:52 AM
Thanks rich harris
Thanks for the full config
I'm planning to do this implementation in the middle of next month
shameer
