Isolated network for UC migration
Yangjp715
Level 2
Level 2
Hi all,
I need to build an isolated network for CUCM migration. The CUCM ip address and gateway is in 10.192.143.0/24, but the IP of the NTP server is 10.192.1.5/24. the following is my lab connection:
ESXi host (VMs in 10.192.143.0/24)-->SW2950(all interfaces are in VLAN1, default-gateway is 10.192.1.5)-->Cisco 2821 G0/0(Primary ip 10.192.143.1/24, the secondary IP 10.192.1.5/24). Is there any way the NTP server 10.0.0.5 can be reached from VMs in 10.192.143.0/24?
Thanks in advance,
Eric
11 Replies 11
Yangjp715
Level 2
Level 2
Router configurations:
Current configuration : 1307 bytes
! Last configuration change at 22:51:56 UTC Sun Jul 15 2018
! NVRAM config last updated at 22:51:58 UTC Sun Jul 15 2018
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2821 sn FHK1306F3D9
redundancy
interface GigabitEthernet0/0
 ip address 10.192.1.5 255.255.255.0 secondary
 ip address 10.192.143.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.192.1.0 255.255.255.0 GigabitEthernet0/0
ip route 10.192.143.0 255.255.255.0 GigabitEthernet0/0
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master 4
end
Switch:
Current configuration : 1467 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 no ip address
interface FastEthernet0/2
 no ip address
interface FastEthernet0/3
 no ip address
interface FastEthernet0/4
 no ip address
interface FastEthernet0/5
 no ip address
interface FastEthernet0/6
 no ip address
interface FastEthernet0/7
 no ip address
interface FastEthernet0/8
 no ip address
interface FastEthernet0/9
 no ip address
interface FastEthernet0/10
 no ip address
interface FastEthernet0/11
 no ip address
interface FastEthernet0/12
 no ip address
interface FastEthernet0/13
 no ip address
interface FastEthernet0/14
 no ip address
interface FastEthernet0/15
 no ip address
interface FastEthernet0/16
 no ip address
interface FastEthernet0/17
 no ip address
interface FastEthernet0/18
 no ip address
interface FastEthernet0/19
 no ip address
interface FastEthernet0/20
 no ip address
interface FastEthernet0/21
 no ip address
interface FastEthernet0/22
 no ip address
interface FastEthernet0/23
 no ip address
interface FastEthernet0/24
 no ip address
interface Vlan1
 ip address 10.192.1.4 255.255.255.0
 no ip route-cache
ip default-gateway 10.192.1.5
ip http server
line con 0
line vty 5 15
end
Dennis Mink
I am assuming your isolated 10.192.143.0/24 is also alrady a prod subnet?
in which case, use NAT to hide the isolated 10.192.143.0/24  to allow it to connect to the NTP server
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
The BE6k is in our office, not in customer side. Do i need to replace the 2950 by using a layer 3 switch and configure a default route on it, such as "ip route 0.0.0.0 0.0.0.0 10.192.1.5".
Thanks.
Is there anybody who have ideas for building an isolated network environment in Lab environment? Thanks.
mikeleebrla
The easiest thing to do would be to configure your CUCM to use its own gateway as its NTP server (or any IP in its own subnet). Remember Cisco routers are NTP servers by default. This way there will be no routing issues for the CUCM (production or isolated migration environment) when accessing the NTP server.  In the isolated VLAN get an old cisco router and configure it with an IP in the 10.192.143.X range and configure this router with the "NTP Master" command so it will be its own master and have a low stratum so it will be considered a 'valid' NTP server by CUCM. Remember this router/NTP server will be in an isolated environment so it cannot reach valid NTP server. The "NTP Master" command solves this issue.
The IP of the NTP server in production environment is 10.192.1.5. So i have to use this IP in an isolated environment to restore the configurations.
Why couldn't you change the NTP server to an IP in your production environment?  I've done what I've suggested dozens of time and it works flawlessly.
I asked them before, but the client does not want change anything in their network.
In that case you can replicate what they have in production on your isolated network. You should be able to use your 2821 as the gateway and NTP server all in one using two of its interfaces. Configure one interface with 10.192.143.1 and plug this side into your isolated network.... on another interface on the 2821 put IP 10.192.1.5 on another interface and plug something into it so the interface will be up. Configure the 2821 as an NTP master and then your CUCM isolated environment will then be able to reach your newly created NTP server at IP of 10.192.1.5 (which is just the other interface of your 2821).
CUCM---------10.192.143.1-Router-10.192.1.5---
Thanks Mike, Now the IP address of the NTP is reachable. But i got an error message: Default gateway name/address is invalid or gateway is not responding. Right now i am installing CUCM 8.6 on a brand-new BE6M. I changed Linux to 64 bit based on some postings, but it did not work.
all you need to do to solve this issue is put whatever IP you have set as the gateway in your CUCM config on the interface of the router that 'faces' your isolated CUCM environment. It can be the primary or secondary address on that interface. CUCM just needs something to respond to pings.
