Missing ITL file
bradatbcass
Hi, we're having a strange problem with some of our Cisco 7941 and 7942 phones. To troubleshoot an issue I attempted to manually delete the ITL file (Security --> Trust List --> ITL file) on the affected phones. But there is nothing there, so I can't delete it. When I attempted to factory reset these phones, the phone went into an endless boot cycle, failing to update and displaying a small dot inside a circle on the lower left of the display
Why would the ITL file be missing? I verified the TFTP settings are correct.
The boot cycle indicates we might be missing versions of our firmware on Call manager....any thoughts?
Brad
Jaime Valencia
What CUCM version?
java
if this helps, please rate
Hi Jaime, we're at 10.5.2.10000-5
Brad
Do you see the ITL file on CLI?
java
