ISR 1100 CME
Kalin Hristov
Hello guys
I saw in release notes that the ISR 1100 will support CUBE from 16.9 but no word about CME. Is CME going to be supported in some release or it will not be supported at all? If CME is supported this will be the perfect router.
5 Replies 5
CME is not supported on ISR 1XXX based on the latest CME versions guide.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs128spc.html
Unified SRST 12.8 is only supported by the following platforms running Cisco IOS XE Amsterdam 17.2.X and later releases.
For Cisco 4000 Series Integrated Services Routers and Cisco VG400 Series Analog Voice Gateway platforms (Cisco VG400, Cisco VG450 and so on) that act as client gateways, all NIMs with FXS ports are supported when registered to Unified SRST using SCCP/STCAPP.
Supported Platforms and Memory Specifications: SCCP/SIP IP Phones*
Cisco Platform
Maximum SCCP/SIP IP Phones
Maximum Total Ephone-dns or Virtual Ports
Recommended DRAM in Non-Secure Cisco Unified SRST
Recommended DRAM in Secure Cisco Unified SRST
Recommended Flash Memory
Cisco ISR 4321
50
200
4 GB
4 GB
4 GB
Cisco ISR 4331
100
400
4 GB
4 GB
4 GB
Cisco ISR 4351
700
1000
4 GB
4 GB
4 GB
Cisco ISR 4431
1200
1800
4 GB
4 GB
8 GB
Cisco ISR 4451
2000
2500
4 GB
4 GB
8 GB
Cisco ISR 4461
2000
2500
8 GB
8 GB
8 GB
* Memory recommendations and maximum numbers of IP phones are for common Cisco SRST configurations only. Systems with large numbers of phones and complex configurations may not work on all platforms and can require additional memory or a higher performance platform.
The Maximum Total IP Phones can be split between SCCP and SIP phones as long as the maximum total of IP phones is not exceeded.
Response Signature
Thanks for the replay
Yes, I know that in Amsterdam it is not supported, the question is, is it going to be supported in future releases
Roadmap is NDA, thus, it cannot be discussed in public forums. Reach out to your SE for this question.
java
if this helps, please rate
ma.romero
Level 2
Level 2
I have a ISR1100-4P and I adquiere CME licences for this ISR.
ISRCME#show license summary
License Usage:
License Entitlement Tag Count Status
uck9 (ISR_1100_4P_UnifiedCom...) 1 IN USE
securityk9 (ISR_1100_4P_Security) 1 IN USE
The IOS software is:
Cisco IOS Software [Amsterdam], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.3, RELEASE SOFTWARE (fc7)
I can't use CME here, Do I lost anyone? The command "telephony-service" doesn't exit.
Regards.
Please upgrade to 17.5.1a. This is the first release to support CME. Previous versions only supports CUBE functionality.
home-gw(config)#telephony-service ?
  setup  Start setup for Cisco Unified Communications Manager Express. Please
         refer to
         http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
         for full documentation.
  <cr>   <cr>
